runs then dies
HELP ME PLEASE! UPDATE....so after changing the following parts its still the same, fuel pump/fuel filter/ignition moduel/coil/idel air unit/fuel pump relay and the oil presure sender unit, any help would be most helpful, thanks
Dealing with the same here. 1994 4x4 S10 Blazer 4.3 TBI.
Just got a new distributor (reman) and was swapping that one in. Bugger have to make a long tube with a slit to turn the fuel pump in order to properly drop it in.
What I have come up with is the following:
- I always had spark and fuel injection. This can be normal as during start it runs in closed mode. Fuel means that i have an rpm signal from the ignition module.
- When cold it starts and runs. SES/MIL light is on during cranking (normal) and exinguishes when it runs.
For once I could observe some hesitations in idle and when revving it to 2'000 rpm I got intermittent weird rpm indications. This could be consistent with the no start issue when it becomes steady. Maybe loss of rpm signal.
I've no time to fumble with my ALDL cable and read out the codes. Replacing the distributor maybe today, latest over the easter weekend.
I'll let you know.
I'll let you know.
The problem could be a fuel mixture issue. When the engine is cold the Fuel Mixture is rich and when the engine warms up the fuel mixture is leaned out. The O2 sensor and the Temp Sensor for the ECM controls the fuel mixture once the engine is warmed up. Faulty readings could from one or both could cause the symptoms your having. The Temp Sensor for the ECM is a 2 wire Sending Unit by the water inlet at the front of the engine.
