rusted body mounts 93 blazer - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 12-11-2010, 10:22 AM
akronboy89 is on a distinguished road
Default rusted body mounts 93 blazer
hey guys i was just wondering if any one knows if you can fix the front body mounts if there rusted pretty bad. i just want to see if there is any thing i can do. it is sagging really bad to the pass side.
Old 12-11-2010, 11:01 AM
Anything can be fixed. The direction you take depends on what you have as far as tools and experience.
Are you talking about the body mounts on the front of the cab at the firewall or the ones up at the radiator core support? If it's core support, replacement core supports can be purchased and bolted in. If it's the body itself, then you will have to fab up replacement plates, cut out the old, and weld in the replacements.
Old 12-11-2010, 12:07 PM
ya sorry i didnt put that it is the oned under the cab and it is a s10 blazer. one of my buddys was telling me to put 2x4's under it righr there and bolt them in.
Old 12-11-2010, 03:54 PM
A 2x4 will never last. Even pressure treated would only be a temporary fix and one that would lead to more extensive damage to the body of the truck due to trapped moisture.
What is your goal with this truck? If you just want something to last for a year or so, you can basically do whatever you'd like. If you want it to last a long time, you will need to use metal and get it put back together properly.
Old 12-11-2010, 07:27 PM
its just a daily driver. i just want it to last me
Old 12-11-2010, 11:51 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
LMC actually sells these had to replace them on both sides when i did my rust removal/lift/repaint you can find them at the very bottom of THIS page
Old 12-12-2010, 09:36 PM
ill try and post some pics of the lean tomorrow. i got the truck it had 140k and i got it for $800 all the power windows work the locks the ac is ice cold the interior is mint. the only thing i had to do was pit a FPR on it and one of the fuel rails had a hole in it from onr of the spide fuel legs rubbing in it.
Old 12-28-2010, 07:21 PM
lazer is on a distinguished road
there is also ccg out of ohio but i never used them.
http://www.ccgtruck.com/Merchant2/me...gory_Code=8Res
i got to do left and right front cab too, is it as simple as chisel and grind out old and weld in new?
i think there is also a backing plate?
thanks.
Closed Thread
Thread Thread Starter Forum Replies Last Post
94 S10 Blazer body to frame mount rusted bcny168 1st Gen S-series (1983-1994) Tech 5 11-18-2010 10:15 PM
Rusted Body Mounts Headache! lakeblazer91 Paint, Body, & Interior 4 02-25-2009 08:19 AM
Rusted Body Mounts ANYONE! lakeblazer91 Lifting Tech 1 02-24-2009 08:40 PM
s-10 blazer body mounts greenduster360 1st Gen S-series (1983-1994) Tech 2 04-23-2007 01:30 AM
Another rusted body question Verzwyvelt Paint, Body, & Interior 4 12-09-2006 08:18 PM
Tags
87, 93, 97, blazer, body, bushings, cab, chevy, fix, gmc, mount, mounts, replace, rusted, temporary
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
