slow response acceleration
Old 07-20-2013, 12:35 PM
TheRemedy's Avatar
TheRemedy is an unknown quantity at this point
Default slow response acceleration
I just finished rebuilding my TBI on an 89 4.3L. It drastically improved the performance, and the idle is almost too quiet. One thing I noticed, and something similar to this happened years ago when I drove it more, there was a slight delay in acceleration when I hit the pedal. It took a second then would take off. About 7 years ago this would happen most often when I got off the interstate, and at that time I was getting a MAP sensor error. I've since changed the MAP sensor. Any other emissions sensors I should check, the oxygen sensor maybe? Any ideas are appreciated.
Old 07-21-2013, 06:09 PM
TheRemedy's Avatar
I'm not sure if this could be related, but I noticed today my oil pressure is reading a lot higher at idle. Yesterday it was minimal, maybe 10 psi, today at idle it is showing about 40 psi. Any ideas as to what could cause this?
Old 07-22-2013, 07:18 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
idk about oil pressure but check your egr, it make be sticking open
Old 07-23-2013, 09:58 PM
TheRemedy's Avatar
Thanks, I'll check that out. I think the oil was just running cold, I ran the engine for a while and pressure went down.
tdbone1
12-20-2012 09:40 AM
Chenzo
Engine & Internal
03-29-2011 01:56 AM
ablazer00
09-04-2010 01:43 AM
Jimmysls98
02-28-2007 10:40 PM
beeneeb
02-12-2007 06:44 PM
Quick Reply: slow response acceleration
