Start problem -93 vin W engine
Old 12-08-2014, 11:27 AM
Czenda's Avatar
Czenda is on a distinguished road
Default Start problem -93 vin W engine
Hello, guys. At first,sorry for my english,Im from central europe.
I have a strange problem with my engine in my car (Olds Bravada)- wont start,
but I have a new sparks and wires,rotor and cap its too ok, new fuel pump and sending unit, new relays, all connectors ,and wires its ok, no trouble codes, fuel pressure its 62 psi and stay on (no leaks ,or pressure regulator), new intake manifold gasket.. I do a video, you can hear a "clicking " from a Intake manifold tuning valve relay ( ? its ok??)..
Thanks for the help !!!!!
https://www.youtube.com/watch?v=T8k6...ature=youtu.be
Old 12-10-2014, 01:58 PM
GoldOlds94's Avatar
GoldOlds94 is on a distinguished road
The E.G.R. Valve could be stuck open by having carbon build up. Once a year I take mine off the check/clean. It's located right under your intake with a wire harness and two 10mm bolts. Take off an inspect an clean with carb stray. Make sure the postal is moving freely. It's about a 15 minute job.
Old 12-11-2014, 11:27 AM
Czenda's Avatar
Hello, Thanks.
EGR its clean, and looks good.The "movable part" of egr its stay in "hole" when I pull it down,thats right??.. Today I try next second pump, and coil.. now I have spark, fuel injectors working, pressure regulator too..
It makes me nervous..
Old 12-12-2014, 04:13 PM
Czenda's Avatar
*Update*
fuel pressure now do this :
https://www.youtube.com/watch?v=BKaE...ature=youtu.be
Old 12-12-2014, 06:14 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
your intake is really clean on the regulator side, should be black.
Old 12-14-2014, 03:51 AM
Czenda's Avatar
It was cleaned ..
Old 12-15-2014, 08:56 AM
GoldOlds94's Avatar
Yes the egr petal should move up an down freely. If it's stuck it won't start the engine. With the intake plutuem off and egr valve off you can clean the holes where the egr is. Have you replaced your fuel filter. It's underneath on drivers side in middle of wheel base. I'm not sure about that clicking noise your getting.
Old 12-16-2014, 08:51 AM
Czenda's Avatar
News : Egr move freely.. But I have care about fuel line/pump..
Old 12-18-2014, 02:37 AM
GoldOlds94's Avatar
Wow. I'm stumped on this problem your having with not firing up. The ignition control module might be your problem it's located under you distributor cap that has two mounting screws an a wire harness. It could be your problem. I take it you have checked your fuses under dash by your parking break pedal. It has too be something electrical causing this.
Old 12-20-2014, 07:11 PM
GoldOlds94's Avatar
Any luck yet with the motor starting? I'll do some research for you. I enjoy helping people solve their problemsm.
Quick Reply: Start problem -93 vin W engine
