Start problem -93 vin W engine
Pressure stay on 60 psi, during start, but nothing more..
Still wont start. About ICM, I dont found any bad points, or cracks..
I have a news.. I try dismount and mont back a fuse block.
Now fuel pump relay doesnt fast "clic", abut fuel presure jumps to 60 psi and falling a fast ... and when I try on ignition after 10 sec, fuel again jumps to 60 psi.
Fuel pump pressure is around 60 psi so that's good and there is spark. How about you injectors/fuel pressure regulator. Know as (spider) injector. I had to replace my unit 3 times already. Other then that it hast to be a bad sensor, like crank,cam,oil,coolent sensor.,knock. Just one of those is faulty equals no start. Have you checked the ignition timing?
https://www.youtube.com/watch?v=ZeDC...ature=youtu.be
If I have a rich mixture, engine stops and wont start, plugs are black / carbon and wet from gas.. What its mean.. bad pressure or IAC ? Idle is very bad
Fine, I have a new pressure regulator and next fuel pump.. but When I turn the ignition key, the in-tank electric pump starts up, but the pump relay starts to click-clack very fast. Within few seconds I switch the ignition off and back on and pump relay starts up again instantly – what should not happen, of course. Relay is brand-new, as well as the pump, fuses work well. OBD does not work any more either. This has happened once already, but it stopped of its own accord. Hence, the pump does not pressurize to the original pressure value of 61Psi and I do not know where to look for the malfunction.
Thank to all for help..
