surging idle
Old 12-22-2012, 07:20 AM
blueblazer1969's Avatar
blueblazer1969 is on a distinguished road
Default surging idle
I got my blazer running I thought I had it.right now it has a surging idle and tries to die when you its a 2.8 1988 blazer its throwing a code 34 and 42 any advice on where to start or what could be causing this
Old 12-23-2012, 08:06 AM
I reset the computer now I only get the code 42 this thing will sit and idle in park all day but when you put it in gear and take off when come up to a stop.sign it will die every time
Old 12-23-2012, 09:04 AM
99cbsuv's Avatar
99cbsuv is an unknown quantity at this point
Either your timing is off a little bit ( turn distributor to advance a bit ) or you have a vacuum leak. If turning the distributor and checking timing does not solve your issue, then mix up a spray bottle of soapy water and check for a vacuum leak.
Old 12-23-2012, 04:09 PM
i will check timing tomorrow thanks for the help
Old 12-23-2012, 07:13 PM
ohsofly's Avatar
UnknownFish
22
11-14-2011 07:40 AM
turquoiseblazer
04-24-2011 10:53 AM
GeeWhiz
02-12-2009 03:52 PM
smokincivic98
07-28-2008 12:20 PM
wildboar
05-29-2006 04:35 AM
Quick Reply: surging idle
