tranny fluid - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 01-26-2012, 02:40 PM
vendo is on a distinguished road
Default tranny fluid
Does the tranny fluid go in between the transfer case and trans? my tranny was 4 quarts low and i saw no leaks,is there a seal or any way fluid is leaking into transfer case 1992 Blazer K5
Old 01-29-2012, 06:50 PM
radiokid's Avatar
radiokid is on a distinguished road
Yes you could have trans fluid leaking into the transfer case, if the seal is leaking.
It takes the same fluid however it could be under pressure removing the filler nut on the case should let you know if the tranny is leaking into the case if fluid comes out the top then you know its leaking, or if you have to much fluid in the case. however the trans and Tcase do not share fluid between the two.
Old 01-30-2012, 04:32 PM
guess i will have to take the bolt out...
Old 01-30-2012, 07:31 PM
xgiovannix12's Avatar
xgiovannix12 will become famous soon enough
make sure you remove the filler plug not the drain one
the filler plug is on top
Old 01-31-2012, 05:45 AM
Lol thats a good one,I grew up in a car dealership....al
Old 01-31-2012, 08:02 AM
lol just making sure. I did not mean you did not know what you were doing
Im apologies if it was taking in the wrong way
Old 02-16-2012, 01:12 AM
Matthew Hayes's Avatar
Matthew Hayes is on a distinguished road
Mine does this exact same thing. It overfills the transfer case and the transmission starves for fluid. So it's probably a bad seal?
Old 02-16-2012, 10:57 AM
richphotos's Avatar
Quote:
Yuppers
Old 02-16-2012, 12:12 PM
Mag-300 is on a distinguished road
My Granddad bought a 2000 s-10 4x4 a few years back.It only had around 20,000 miles on it.When we stopped and started to pull up steep hill's it would just sit and the engine would race.
No smoke or spinning of the tires like you'd expect.Finally we put it in 4 wheel low.
Then it would go.
After several time of this happening and continuously checking the tranny fluid which was never low he had an idea.
He remembered the old power glide we had in our 64 chevy.
You had to keep power braking it lightly forward and back to get the true fluid level.
We did this with his truck and bingo it was about 2 and 1/2 quarts low.
I never would have thunk it but man that truck does great still.
Just a small story that may help in the future.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Change Tranny Fluid/Diff Fluid with only 66k BrinkDiamond Engine & Transmission 4 03-02-2014 03:50 PM
Newly purchased ZR2,3 quarts low on Tranny fluids,but it does not leak tranny fluid? ski.dive 2nd Gen S-series (1995-2005) Tech 10 02-07-2014 05:18 AM
how to change transfer case fluid and what fluid is best DaleA 2nd Gen S-series (1995-2005) Tech 6 01-13-2009 08:50 PM
tranny fluid change timetoblaze General Tech Help 2 11-02-2006 01:33 AM
Changed my tranny fluid, what a PITA LT1KICKER General Tech Help 2 10-23-2006 04:00 PM
Tags
1994, 4x4, 92, blazer, case, fluid, gasket, leaks, oil, s10, tranny, transfer, transfercase, transmission, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
