94 blazer 4.3L (W) type temp
Old 06-11-2009, 02:17 PM
bobby.0761's Avatar
bobby.0761 is on a distinguished road
Default 94 blazer 4.3L (W) type temp
When i bought this truck the temp gauge didnt work so i replaced the sending unit on the right side of engine.
It had a leak as well so replaced the thermostat and fixed the leak there.
I also had to replace the radiator.
i then needed a new rad cap as the old one did not hold the pressure on the new radiator.
Now all seems fixed except the temp is at the 210 mark.
So Im wondering what the normal operating temp should be for this truck.
Thanks
Bobby
Old 06-11-2009, 02:20 PM
ClueMeIn1989's Avatar
ClueMeIn1989 is on a distinguished road
the normal should be a little below the halfway mark.. It can fluctuate around that area.
Old 06-11-2009, 02:40 PM
rriddle3's Avatar
Normally, 190-200 degrees. It uses a 195* thermostat. Factory gauges are not all that precise, so I would not worry if it reads 210.
Old 06-11-2009, 04:26 PM
91chevywt's Avatar
91chevywt is an unknown quantity at this point
Mine reads right at 210 in my '94 vin W, and I'm sure thats about where it should be.
Old 06-11-2009, 08:04 PM
Typical fluid temperatures for a 195*F thermostat are in the 200-210*F range. Sounds perfectly normal to me.
Old 06-17-2009, 11:27 AM
bobby.0761's Avatar
thanks for the replies.
yesterday in town stop and go it rose to the 240 or so. i'll keep an eye on it.
bobby
Old 06-17-2009, 06:16 PM
Yeah, 240 is high.
Have you cleaned the finned area of the radiator out?
96jimmyslt4x4
07-18-2011 10:08 PM
zakm0n
01-09-2011 07:31 PM
davidsv8mustang
12-08-2010 10:23 AM
DaddyCop03
05-11-2008 09:07 PM
naf821
08-08-2007 07:19 AM
Quick Reply: 94 blazer 4.3L (W) type temp
