vortec 4.3 knock sensor location VIN W
Old 06-01-2010, 05:59 AM
rocknroadie's Avatar
rocknroadie is on a distinguished road
Default vortec 4.3 knock sensor location VIN W
I've got a '92 jimmy that's throwing a code 43, but I can't even find the second knock sensor to test it.
The one I found is the one in the passenger side cylinder head, which seems to be OK. I've read that the other one is supposed to be in the vicinity of the distributor cap (some say below, some say to the right of,) but no amount of poking around there has lead me to find it.
They say a picture is worth 1000 words, can someone post a pic of where it's supposed to be, so I can (hopefully) stop bloodying up my hands with this thing and move on the the next job?
I wouldn't be surprised if the previous owner pulled it for some reason and just threaded a bolt in where it was supposed to go... he was that way.
Old 06-01-2010, 06:38 AM
The image below shows the location of the rear knock sensor on the 96+ SCFI engines:
Your second sensor could be in that location.
Also, my references show the possibility of it being located in the back of the cylinder head... It is a bit unclear. But that should get you closer.
Old 09-02-2010, 06:14 PM
Bigchief's Avatar
Bigchief is on a distinguished road
I am trying to find the location of the knock sensor on my 96 Chevy Blazer. Can not find it. Can somone please help with a pic.
Old 09-02-2010, 06:34 PM
Did you look at the picture posted above?? Its clearly pointed out.
Old 07-01-2011, 02:40 PM
btb1003's Avatar
btb1003 is on a distinguished road
On my '93 S10 4X (W) the second is located on the back of the passenger side cylinder head and a beast to get to
Old 07-01-2011, 06:19 PM
mxpxpunkrock1987's Avatar
mxpxpunkrock1987 is on a distinguished road
passenger side lower part under exhaust manifold the one u are refering to is the cam sensor which is known for causing problem which is located on disty
xgiovannix12
08-25-2012 02:43 PM
Cdon294
12-22-2010 09:23 PM
SlydinClyde
10-18-2009 08:14 PM
kingzero
08-09-2009 12:15 PM
BlazerSS
Engine & Internal
04-21-2007 03:44 PM
Quick Reply: vortec 4.3 knock sensor location VIN W
