where is horn relay located? - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 01-09-2010, 01:22 AM
rastoma is on a distinguished road
Default where is horn relay located?
93 s10 blazer, 4.3 W
There is supposed to be a horn relay besides the fuse. I know the location of the fuse, but trying to diagnose why horn doesn't work.
Old 01-09-2010, 03:44 AM
Gimpy Blazer is on a distinguished road
According to my 94 Service Manual, it's located in the "Convenience Center" although I don't think it's very convenient. You have to remove the interior panel under the steering column and to the left you will see a relay, alarm module and flasher. The horn relay is the square looking one on the lower left.
Old 01-09-2010, 08:16 AM
Quote:
That would be correct.
Old 01-09-2010, 04:50 PM
Great thanks.
It's a general relay right? Meaning it can be swapped with another to diagnose?
Old 01-09-2010, 07:00 PM
I have to look. What's the problem anyway? You might pull it and compare it to another one that's easily accessable. I'll check my wiring diagram. Man, relays are cheap.
Checked wiring diagram.
Don't want to wear you out but most of the time they aren't working.
This is a pretty simple relay - only 3 pins. I don't remember seeing any other 3 pin relays on my vehicle - not to say there aren't any. This system is pretty easy to troubleshoot. Basically you have a hot wire (Orange) that goes to slot L on the convenience center (CC) (relay pin 1). When you press the horn button, it grounds the relay through the CC slot M (relay pin 3) and the relay then closes supplying voltage through CC slot N (relay pin 2) and out the Dark Green wire to the horn. If the horn isn't working I would check the following.
1) Horn mounting bolt for being clean and tight - this is the ground for the horn.
2) Pull the relay and jump between CC slots L & N. If the horn sounds, the manual says to replace the relay.
3) With relay removed hook up a meter for continuity between CC slot M and ground and press the horn button - should have little or no resistance (infinity)
4) Check for voltage with test light or meter at CC slot L - this is your "hot at all times" wire (Orange)
5) Beat on the horn a little - sometimes they stick. A little WD 40 sometimes does the trick too.
Old 01-10-2010, 03:37 AM
Wow Gimpy, that's pretty cool.
Thank you so much for the time and effort in listing that. You along with the other regulars that take the time to go the extra mile in offering assistance makes this place pretty awesome
I just wasn't checking the correct items. I didn't know there was a horn relay until a couple of days ago so I was just trying to troubleshoot based on the horn fuse and the wiring to the horn. The horn just doesn't work. But I'm going to go through the steps you listed tomorrow and hopefully will finally be able to pinpoint the fault.
Did you get that info from a service manual? I have a Haynes book but I didn't see anything like that in it.
Thanks again.
Old 01-10-2010, 07:55 AM
I got some of it from the S/M (factory is the only way to go man), some from the wiring diagram and some of it from experience and seeing the obvious. Never had any luck with Haynes. Chilton only slightly better. You can still buy the factory books. They have saved me a bunch of time and money. Worth every dime and they ain't cheap. Sometimes you can find them on e-bay if you wait long enough. There are 3 manuals that make up the set although you really don't need the "Unit Repair Manual" unless you're going to overhaul something. Let ,e know if you want the website.
Closed Thread
Thread Thread Starter Forum Replies Last Post
97 Blazer horn relay location mjrjarhead 2nd Gen S-series (1995-2005) Tech 0 08-04-2012 11:22 AM
'94 - A/C Relay...Relay Block...Need help jumping bestes 1st Gen S-series (1983-1994) Tech 2 05-31-2008 04:16 PM
2000 S-10 Horn Relay atbauer Audio/Video Electronics 11 07-22-2007 10:03 PM
Where is the encoder motor located? CaboKP 2nd Gen S-series (1995-2005) Tech 1 01-27-2007 04:44 PM
horn relay? tasakahr General Tech Help 1 11-18-2006 04:12 AM
Tags
1974, 1994, 1995, blazer, chevy, fuse, gm, hookup, horn, location, pickup, relay, replacement, s10, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
