why am i blowing rear brake cylinders
Old 04-18-2009, 07:08 PM
marine1jpp's Avatar
marine1jpp is an unknown quantity at this point
Default why am i blowing rear brake cylinders
I have replaced a couple of left rear wheel brake cylinders. I just had to replace a porportinal valve and when i went to bleed the system another left rear cylinder is in pieces in my drum. The chance that i could be doing something wrong is at the top of my list so any help would be great.
Old 04-19-2009, 07:19 PM
How are your brake shoes? If they are worn hard, they can allow too much travel in the wheel cylinder.
When you put everything back together, how much room is there between the shoes and the wheel cylinder?
Old 04-22-2009, 02:19 PM
mr.vls's Avatar
mr.vls will become famous soon enough
Same thing if your drums were turned too much also If your shoes are not adjusted correctly and the self adjuster is not working, that could add to the problem.
Hank3band
09-20-2011 09:08 AM
blazinloud
01-05-2011 10:29 AM
Concerned
04-01-2009 07:01 PM
hazzman52
11-10-2008 10:45 AM
guillermoariast
01-26-2007 05:26 PM
Quick Reply: why am i blowing rear brake cylinders
