01 BLAZER PCM LOCATION
Old 03-26-2007, 05:38 PM
johnny_5's Avatar
johnny_5 is an unknown quantity at this point
Default 01 BLAZER PCM LOCATION
2001 blazer 4x4 4.3l. hey, anyone know where i can locate the pcm on my blazer..? yes, im new, so please bear with me as i learn the ropes here... thanks in advance
Old 03-26-2007, 05:49 PM
Default RE: 01 BLAZER PCM LOCATION
Passenger fender on top of coolant tank, it should be black with small fins and 4 connectors, with the words "BLACK" and "WHITE" on top.....
johnny_5's Avatar
this thing was running super, had it idling in my driveway, getting ready to leave for work, all of a sudden, it just shut down, i have the code reader, so after 10 min. of cranking the enging over, i plugged in the OBDII and came up with error code p1637,"altenator l terminal circuit" icalled the dealer, who informed me its caused by a bad PCM module. 235.00 plus re-programming fee's. but i have to locate it first, as they want a core for trade in... any help would be greatly appreciated... thanks
Old 03-26-2007, 05:51 PM
johnny_5's Avatar
i have an aluminum box, ontop the coolant tank, says "L - BLUE" could that be it..? thanks
Old 03-26-2007, 05:55 PM
ORIGINAL: johnny_5
Maybe this will help:
[IMG]local://upfiles/1127/3925E720041D4B0DB00867692265DB9E.gif[/IMG]
Your computer is different than what mine looks like...
Old 03-26-2007, 06:02 PM
johnny_5's Avatar
yes, thanks so much,, is there any special way of removing it..? looks pretty simple, jeeze, i sure hope this solves the problem
Old 03-26-2007, 06:33 PM
I don't want to tell you the wrong thing but from what I have read about these computer problems is that you should check all the wiring first that would indicate this problem and related to it. The OBDII system can be cryptic at times and just going by the initial code reading does not always solve the problem...sometimes what looks like a sensor computer problem could be a bad/weak connector or broken wire related to the DTC code. So I would check the altenator wiring and the wiring at the computer...before I replace the computer....but then I have time to check these things out...
Old 03-26-2007, 07:52 PM
johnny_5's Avatar
thanks mark, i went thru all the wiring, under the hood. seems to be like new. the PCM , however, has some pitting in the aluminum housing. when this first happened, i checked for fire at the plugs, and found none at all, it's getting gas ok, just no spark to ignite it.
john
miztic2u
07-10-2012 05:37 PM
miztic2u
07-08-2012 07:21 PM
cartunez2004
08-24-2009 06:35 AM
dunontme
07-29-2008 12:09 PM
racenut
12-24-2007 12:05 PM
Quick Reply: 01 BLAZER PCM LOCATION
