1995 Blazer S-10 rear-end noise,
Old 08-23-2011, 02:27 PM
insanefirewall's Avatar
insanefirewall is on a distinguished road
Default 1995 Blazer S-10 rear-end noise,
Driving is all fine, it dont happen all the time just once in a great while, and seems to only make a noise when i turn. to me it sounds like its comming from the drivers side rear wheel. took the tire and hub off all looks fine and dry. its not a hard grinding noise or anything, but kinda like somethings loose in there..
hasnt happened for a few days now.
any ideas?
Old 08-23-2011, 09:07 PM
xgiovannix12's Avatar
check your leaf springs and shackles could be the bushings went its a possibility
Old 08-24-2011, 03:45 AM
shackles?
Old 08-24-2011, 12:48 PM
shackles are the back brackets that hold your leaf springs to your frame
there is bushings in the leaf and in the frame also there should be one in the front . If you jack the back of the truck up and try to shake the leaf see if the noise is coming from there.
Picture of a shackle is posted bellow
Old 08-24-2011, 03:50 PM
found it on the truck, will try that
Old 08-24-2011, 05:47 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
u have 4x4? Could be a broken torsion bar mount. they only make weird noises when turning.
Old 08-24-2011, 07:49 PM
yep its 4 X 4. but it hasnt done it in about 4 days, and i cant re-create the noise if i try. Ive been stopping hard and turning, turning hard, sharp, slow, everything just wont make a noise lol. But i dont think its a torsion bar, it sounds from rear end, and Pretty much like sometings really loose inside the rear wheel hub. but its all good in there...
Doug Fields
08-26-2013 10:15 AM
Hairball
04-08-2012 09:12 AM
brino1
02-25-2011 08:05 PM
Chrismacster
04-02-2009 06:57 PM
isfumpire
05-17-2006 05:24 PM
Quick Reply: 1995 Blazer S-10 rear-end noise,
