1995 Blazer won't idle, excessive fuel consumption
Old 01-31-2012, 11:22 AM
choover82's Avatar
choover82 is on a distinguished road
with the tps disconnected, is there supposed to be a change in engine sound? or maybe supposed to die?
Ive disconnected mine just for giggles and idle didnt increase not did engine die. ( i dont have a voltage tester, but tomorrow I will have a scan tool)
  #92
Old 01-31-2012, 11:49 AM
pettyfog's Avatar
Xenon: Yes it could very well mean the IAC is sticky. The engine should not idle higher than 700 Rpm when warmed and in closed loop. The PCM doesnt want it to unless it cannot control air flow.. like with a vacuum leak, but you dont have a vacuum leak. or it wouldnt idle down till it dies.
SOMETIMES you can clean the IAC, usually it isnt worth it. Replace it. And then put the stop screw back where it was.
No... The TPS is used to set some baselines while cranking* but mainly for acceleration timing/fuel mixture/shift points. In a parked idle, it should not affect rpm.
* At WOT {above 4.5} reduce injector pulse-less gas; output changing while crank - increase injector timing - more gas.
  #93
Old 01-31-2012, 04:09 PM
Xenon's Avatar
Xenon is on a distinguished road
Ok. Thanks for all the help! If it keeps up I will replace the IAC.
  #94
Old 02-01-2012, 12:34 PM
choover82's Avatar
Decided to disconnect tps and start truck...idles high without it.
  #95
Old 02-01-2012, 01:42 PM
pettyfog's Avatar
That's good to know.
See what I mean about setting 'baselines'?
Next thing to try in getting to know the system is warm it up to op. Disc tps while idle then goose it a couple times. I'm guessing the PCM will set a new baseline and probably idle at about 1000.
  #96
Old 02-08-2012, 03:07 PM
Xenon's Avatar
Well I've been driving the Blazer some. It still idles erratically... when I have the money I'm going to replace the IAC and I think that will solve it.
Really love this little truck... seems to do decent on fuel and is a blast to drive... Not bad looking either...
DMShorkey
11-24-2011 05:59 AM
JNR004
05-17-2009 09:42 AM
Davis83
Performance & Brainstorming
15
12-07-2008 03:59 AM
spiritwild
02-10-2007 07:40 PM
Ahmad
Engine & Internal
16
03-21-2006 12:20 AM
Quick Reply: 1995 Blazer won't idle, excessive fuel consumption
