1995 Hesitation issues
Old 09-08-2012, 09:12 PM
awhoff's Avatar
awhoff is an unknown quantity at this point
Default 1995 Hesitation issues
I am hoping someone can provide help on the hesitation problem I am
having with my 95 Blazer, It is a 4dr, 2wd V6 4.3. It starts and idles fine, however
when I put it in D and press the gas it hiccups and hesitates. Me and my friends
have already check fuel filter, and replaced the Idle Air Control Valve. In the last
year i have already replaced the ECM, EGR, Spark plugs and wires, and distributor.
Old 09-08-2012, 10:07 PM
Dadatone's Avatar
Dadatone is on a distinguished road
Have you done a fuel pressure test on the truck? When was the last time you inspected your spark plugs? Are they clean, showing a lean burn or clogged?
Old 09-09-2012, 07:44 AM
50lb_cat's Avatar
+1, also try cleaning the MAF sensor.
Old 09-09-2012, 02:07 PM
viper1ex19's Avatar
viper1ex19 is on a distinguished road
Let me know when you figure this one out.
My truck has been sitting in the driveway for over a month with the same problem.
NOTE: I AM NOT GETTING A CHECK ENGINE LIGHT!!
And YES it works; I made it come on by unplugging my MAF Sensor to make sure.
I have noticed when I first start it up it runs great for about a minute or two.
I mean it runs like a brand new one but after it sits there and idles for about 1 minute it seems like the timing is off or something and it will backfire if you crack the throttle open really fast.
I'm letting mine sit until I get some extra cash to go at it again.
I've replaced the following with mostly AC Delco or Delphi parts;
Fuel Pump
Fuel Filter
Fuel Injection Spider w/ new pressure regulator
Distributor Cap
Rotor Button
Spark Plugs
Plug Wires
Camshaft Position sensor
ECM- With a known good used one flashed to this trucks Vin#
Map Sensor
Idle Air Control Sensor
Throttle Position Sensor
EGR Valve
Purge Valve
Alternator
Catalytic Converter
Tested:
· 02 sensors
· Crankshaft Position Sensor
· Physical Timing (with dist cap off turn crank back and forth to get a approx degree)
· Ignition Switch (connections/ground/hot)
· Did the wire wiggle test to see if it made any difference when I wiggle the wires around
I don’t know where to go from here but when I figure it out I will post it because this seems o be a common problem with these aggravating little pains in my ***.
Old 09-09-2012, 03:45 PM
awhoff's Avatar
well just got back in from the garage, plugs look great and my 95 does not have a MAF.
Replaced the fuel pump today because i had already bought it and have the same issue.
Idles fine, upon acceleration it lopes before it is willing to go.
Old 09-09-2012, 07:14 PM
viper1ex19, The OP has a 95 with CMFI, your 97 has CSFI: two totally different computer control and fuel injection systems requireing totally different diagnostics. Best if you start another thread, we can help you diagnose yours in that thread.
Blazerdave95
09-02-2011 06:06 PM
magg383
02-16-2011 12:32 PM
randy2009
07-22-2010 06:38 PM
shesrdy2laff
05-13-2010 07:55 PM
Numba1Sean
41
05-27-2009 08:55 PM
Quick Reply: 1995 Hesitation issues
