98 Blazer Front driver door won't lock and dome light flickering?
Odd situation here...
Started a few days ago, was driving home from school, when my dome light started flickering on and off. So I just hit the dome override and it stopped that. Just out of habit, I was in a pretty rough neighborhood, so I went to lock my doors. 3 of the four locked, with the exception of the driver door. It went to lock, but then would unlock itself automatically. This went on until I got home, and I parked and turned the car off to check out the problem. Having the door open and the blazer turned off fixed the problem! The door would lock again, and the dome light went off when I closed the door.
Then for 2+ days I didn't drive it(had a pretty big blizzard), then this afternoon, I was driving to visit my mom, same problem. When the car was running, I had the same issues as described above, but, as soon as I parked and had the door open, the problem was fixed.
Any suggestions as to what this could be? Thanks for any and all suggestions!
My first guess would be to check out the door pin on the driver's side. Not the pin/bushing that the door hangs on but a little sensor in the dash, facing outwards towards the door that tells the truck whether the door is open or not. If there is intermittent contact on that pin or an electrical problem with it, it could be the source of your problem. I would check for frayed or crimped wires leading to that sensor.
pin seems ok, little bit loose but seems to be making proper contact. New thing I noticed, the lock only unlocks when I have the key in the ignition and its turned at least a little bit. If the key is out, or just sitting in the ignition, the door locks fine.
BloodOfTheNorth
02-25-2013 08:11 PM
dano440
05-11-2012 06:57 PM
tylersdad0108@yahoo.com
06-11-2010 04:20 PM
ussexplorer
04-09-2010 11:49 PM
