front to rear brake line
I'm about to do a intake manifold gasket job on my 03 S10 blazer 4.3. Anyone have any advice on how to remove the fuel lines and to mark the distributor. Marking the distributor for the correct engine timing. Thanks advice well appreaciated.
For the fuel lines, check the under hood fuse box and look for the fuel pump, take it out and don't forget what side goes what way , try to start it and for like 10seconds after it dies(this removes all the fuel pressure) replace fuse and then dont forget to disconnect battery For the line its a bit of a tight spot, get a short wrench or a cheapy and cut it to length , sorry forgot what size.
For the Distributor get a straight edge and mark on firewall, I used a metal socket holder, simple and multipurpose.
Xavier
04-11-2014 11:49 AM
wisowebs
12-26-2013 06:58 PM
dj00140
03-02-2011 08:52 AM
