1996 LT Blazer 4X4 Auto,,idling to stall engine
Old 11-20-2010, 07:29 PM
wasume's Avatar
wasume is on a distinguished road
Exclamation 1996 LT Blazer 4X4 Auto,,idling to stall engine
Hi all,,i have change the fuel pump and regulator + fuel filter,,,for some reason after i change my regulator the engine would stall @ idle, but okay when driving???any input would be apreciated,,thank you
Old 11-20-2010, 07:35 PM
Just because parts are new doesn't guarantee that they're good. Recheck fuel pressure and leakdown, this thread tells you how to check it: https://blazerforum.com/forum/showthread.php?t=45941
If it's OK, the Idle Air Controller, (IAC) might need to be reset with a capable scan tool.
Old 11-21-2010, 06:01 AM
wasume's Avatar
Thanks for reply,,yes check fuel pressure and leakdown all is good.....i don`t have a capable scan tool and yes i have not reset this,i have an OBD2 TekLink,,,my guess his time to bring it in a shop..
when i change my fuel regulator i did Not replace any gaskets,they seem okay,,,should i get new gaskets and O rings and re-due the job?thanks
one more? if i disconect battery will it reset the Idle Air Controller?thanks for all your help
Last edited by swartlkk; 11-21-2010 at 02:52 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old 11-21-2010, 12:51 PM
Always a good idea to replace the gaskets and O rings when removing the plenum along with using the correct tightening sequence and torque specs. Disconnecting the battery will not reset the IAC. It requires a bidirectional scan tool to access the IAC reset function.
Old 11-22-2010, 07:19 AM
wasume's Avatar
Thank you Captain Hook,very heplful,will post after i redue the job
Old 12-10-2010, 12:27 PM
wasume's Avatar
Thumbs up gasket kit
Thank again Captain Hook,i buy gasket kit for the spider and replace all and now idle back normal,no more stalling,,yes,,,,Thanks all
pselby007@yahoo.com
11-29-2014 08:03 PM
Muscrat
06-12-2014 08:48 PM
abohanon
08-30-2011 03:33 PM
kstanley
08-02-2009 10:32 PM
jim8264
06-19-2006 01:37 PM
Quick Reply: 1996 LT Blazer 4X4 Auto,,idling to stall engine
