1997 Blazer - installing heated mirror in non-heated
Old 03-30-2013, 04:29 PM
1997GreenBlazer's Avatar
1997GreenBlazer is on a distinguished road
Default 1997 Blazer - installing heated mirror in non-heated
I know this is uncharted territory - and I found all the diagrams I could on the forums.
I have a 1997 Blazer with the standard power mirrors. I had to replace my drivers side and came across a heated drivers mirror from another 97.
Mine has the 4 pin hookup, this has a 6 pin.
I did remove the door harness off the donor Blazer. The door has 5 wires going to the mirror plug. Orange, Black, White, Yellow, Green. I'm assuming the black is the heater wire as it's the only added color.
Now, I'm thinking this black wire should be wired to the rear defroster timed circuit. And I did find that well documented diagram. I'm figuring to tap the output wire that comes from the "Solid State Timer".
My question is this...where is this timer located?
Old 09-24-2020, 07:42 AM
allenm7276's Avatar
allenm7276 is on a distinguished road
Are the mirrors on a blazer the same as on a C1500? I am trying to do the same swap, so far I have not found the part number for the power adjust/ power fold. Any help would be really appreciated.
Old 09-24-2020, 11:49 AM
LesMyer's Avatar
LesMyer will become famous soon enough
You will need to tell us the year of the C1500 power adjust/power fold mirror that you want to use.
Old 09-24-2020, 04:16 PM
allenm7276's Avatar
The year is 2000 C1500
Old 09-25-2020, 02:17 PM
LesMyer's Avatar
Seems they apparently did not make a heated, power adjustable, power folding mirror in Silverados until 2003. Two RPO codes. DL3 and the trailer towing one is DPF. There is module programming differrence between the two on the same year truck so there is more to this than the mirrors and wiring.
You can find a replacement in Rock Auto under 2003 Silverado. Doubt if they fit doors other than 2003-2006.
My 2004 Avalanche has the DL3 mirror RPO code. I think both the power folding and heated option is broken on both sides, but the power adjustment works.
Hope this helps somehow.
Old 05-19-2021, 08:45 PM
Mrsm's Avatar
Mrsm is on a distinguished road
Default 2021 Chverolet blazer rs
Why is my driver side mirror getting hot only when I turn it on plz help thanks
Old 05-20-2021, 05:17 AM
This is for the 2nd gen, you will want to start a thread in the new blazer section.
But I honestly think you might get a faster response at a dealer,due don't have many members here with the new blazer YET.
please come back and update if and when resolved to help others!
Old 05-20-2021, 09:00 AM
This. And it's under warranty so, if there's something worong with it, let the dealer worry about it.
SL5417
38
12-19-2013 10:51 PM
showboat
01-06-2012 12:20 PM
JST4SHO
12-21-2011 11:50 AM
cool2drblazer
11-03-2007 10:15 PM
Blade69
04-30-2005 10:12 PM
Quick Reply: 1997 Blazer - installing heated mirror in non-heated
