1999 GMC Jimmy won't start without starting fluid...
Old 11-26-2011, 09:55 PM
PayneSource's Avatar
PayneSource is on a distinguished road
Default 1999 GMC Jimmy won't start without starting fluid...
1999 GMC Jimmy 4x4 - 4 door - 4.3l - 195,XXX miles
So I've been reading through massive amounts of threads via the "Search" function, but wanted to get everyone's opinion before I drop the tank and put in a new fuel pump.
Here is the issue:
  • Car will not start without using starting fluid.
  • Once I use starting fluid the vehicle will start up and will remain running (only in park, haven't attempted to drive out of the garage).
  • While running I can slowly accelerate without the engine stalling, but once I try to accelerate aggressively the engine will stall. After it stalls I would have to use more starting fluid to restart the engine.
I bought the Jimmy in February 2010 and it now currently has 195,XXX miles on it so I'm not sure what all had been replaced prior to my purchase. Since this incident happened I've changed the following hoping it would be something far less expensive than a fuel pump
  • Fuel Filter
  • Fuel Pressure Regulator
  • Throttle Position Sensor
Next weekend I'll be renting a fuel pressure tester to see if the system is getting to the appropriate pressure. Does anyone have any additional ideas?
Old 11-27-2011, 06:14 AM
step66's Avatar
Yup! Check the pressure,but I think you will need a new pump!
Old 11-27-2011, 12:32 PM
Following this flow chart will determine the problem, then no "opinion" will be necessary, it will be a "fact" what the problem is https://blazerforum.com/forum/tech-a...agnosis-23038/
JESSEDG
03-21-2014 12:36 PM
blazintammy
12-05-2013 08:32 PM
lukeawilliamson
15
04-04-2012 05:26 PM
kearney99
07-27-2011 10:24 PM
londonmazda
10-19-2010 02:15 AM
Quick Reply: 1999 GMC Jimmy won't start without starting fluid...
