2000 Blazer A/C recharge problems - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 06-08-2009, 08:56 AM
Jello0123 is on a distinguished road
Default 2000 Blazer A/C recharge problems
I have had to take my blazer in for an A/C recharge the last two years in a row. They can't find a leak so they fill it and the charge lasts all summer, I am content to just fill it each season rather than have them tear it apart and charge me an arm and a leg. I got the bright idea to charge it myself this year and went to autozone and bought a charge kit (Quest / 32 oz. of Refrigerant and 4 oz. of Sub Zero Booster A/C Recharge Kit). I watched an instruction video on youtube and it seemed simple enough. The problem I have had is that the hose from the kit doesn't fit correctly on my accumulator so the refrigerant won't go into the system. I saw on JC Whitney's website another kit which has this comment (includes special high-side adapter for some '91-02 GM systems.) Is this my problem? Does my 2000 blazer have a different connector on the accumulator. I am $40 into this now and don't want to spend another $50 if this won't fix my problem.
Any help would be appreciated, it looked so simple in the video.
Old 06-08-2009, 10:01 PM
If you are trying to connect to the fitting shown as the low side in the image above, you either are not doing it properly, or something is wrong with one of the connectors.
Old 06-09-2009, 06:49 AM
I am connecting to the "low side" off of the accumulator. The hose that came with the recharge kit will fit onto the port but will not lock in place and no coolant will flow from the can into the system. I am curious if there is a difference in the Blazer's low side port vs. other vehicles or if the recharge system that I have is somehow flawed. I don't want to spend another $40-50 to get another recharge kit if it too won't fit on the vehicle. (See original post) That is why when I saw the one from JC Whitney and they mentioned the special fitting on some Blazers I was curious if anyone else knew of this or have come across this issue.
Old 06-09-2009, 08:22 AM
portcqb is an unknown quantity at this point
All r134a systems have the same low side port,some high sides differ. Based on pics of the kit it has the piercing type cans that you just screw the valve/gauge part on top tightly and it will pierce the can, and then the other side should snap on the low side port. They wiggle some since they are only plastic,but it should allow you to put gas into the system.
Old 06-09-2009, 10:23 AM
So then my low side port is not different and even though the connector on the hose didn't "snap" in place on the port itself I should be able to put refrigerant into the system. I played with it for over half an hour and the only sound I heard was the remaining refrigerant coming out of the system when I wiggled the connector on the hose on the low side port, it didn't sound as if any was going into the accumulator. I guess I will try it again.
Old 06-09-2009, 10:57 AM
Yeah most of cheap plastic connectors dont seal great, you should be able to get it to sit on there and pull back lightly and it should seal well enough to go in. The only ones that seal good are the brass couplers.
Old 06-09-2009, 12:00 PM
Thank you portcqb. I will attempt to fill it again within the next day or so. I was a little confused about the directions, unscrewing the gauge to check the pressure seemed to work and confirmed it was low, but when I screwed the gauge down to pierce the can nothing seemed to happen and the gauge didn't move.
Old 06-09-2009, 02:15 PM
coolvette01 is on a distinguished road
I'm not trying to make you feel dumb but when you screwed the fitting in to pierce the can did you screw it back out to open the valve. And also the car needs to be running with the a/c on. If the pressure is low enough then you might have to jump the connector on the pressure switch to get the compressor clutch to kick on. If you do this just watch your pressure, you don't want to put too much.
Old 06-09-2009, 05:59 PM
RonJon is an unknown quantity at this point
The hose MUST snap on the fitting otherwise it won't open internal valves on both the hose side and the fitting side. (and nothing flows) Try this: On the hose fitting is a ring that slides up and down. Slide the ring up and while holding it up, push the hose firmly on the accumulator fitting, then while pushing the hose onto it - slide the ring back down with your other hand. The hose should stay snapped on the accumulator if you give it a firm tug otherwise it won't work.
Old 06-09-2009, 08:06 PM
Quote:
Bingo. The set of gauges I have has quick connect fittings which means that you can just push them on and they will lock in without pulling back on the locking collar. Most have to have the collar pulled back prior to pushing it on.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Recharge 95 Blazer A/C carterx 2nd Gen S-series (1995-2005) Tech 26 05-25-2014 12:00 AM
Leak-detecting A/C recharge with leak fix ... abadinalbany 2nd Gen S-series (1995-2005) Tech 2 06-01-2009 08:27 PM
AC recharge 97 Blazer brf2 2nd Gen S-series (1995-2005) Tech 4 05-19-2009 07:56 PM
a/c recharge blazerlt01 2nd Gen S-series (1995-2005) Tech 2 06-18-2007 07:51 PM
A/C Recharge? hockeykid15 2nd Gen S-series (1995-2005) Tech 8 05-07-2007 10:02 PM
Tags
1995, 2000, 99, ac, blazer, compacity, compressor, kit, oz, problems, quest, r134a, recharge, refill, stay, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
