2000 S10 Blazer - Heater Core Headache
Old 03-23-2011, 11:54 AM
Marbles Racin's Avatar
Marbles Racin is on a distinguished road
Angry 2000 S10 Blazer - Heater Core Headache
I understand that when removing the heater core that the dash will need to be mostly removed. Anyone experienced in doing this...can you give me some heads up information? Thks
Old 03-23-2011, 12:07 PM
TMM217's Avatar
TMM217 is on a distinguished road
before ya start why you trying to replace core is it totally shot. Hope thats not a stupid ?
Old 03-23-2011, 12:32 PM
ravenhurst's Avatar
ravenhurst is an unknown quantity at this point
https://blazerforum.com/forum/articl...-thread-36252/
Sometimes you have to go back a few pages with the search feature but there is a huge amount of info on heater cores on this site. It's a lengthy job, but its really easy to do. Label all your wires and keep track (notepad or something) of everything that is disconnected and where. If you forget to reconnect a wire on the rebuild, you'll have major problems.
Attached is the condensed version of whats in the thread above. But the link above has lots and lots of pictures. There's also pictures of the job in my profile here.
File Type: doc
Old 03-23-2011, 05:22 PM
idrd's Avatar
idrd is on a distinguished road
Like Ravenhurst said, not really a huge job, just some time involved. Just finished mine in a 1996. If you follow the directions ( and save all the bolts) its actually not bad at all. Hardest part for me as I have big arms, was once the dash was disconnected, getting behind it to disconnect the 4 or so wiring harness's behind the glove box area.
Honest, take your time, do not drink beer and it will all work out. If its leaking and you are not ready to do it, just bypass it inside the engine compartment by looping the two heater hose lines together for now. Good luck
Old 03-24-2011, 12:29 AM
KopterDr's Avatar
KopterDr is on a distinguished road
Im getting ready to change mine this weekend. Use the search feature on tool bar for help. Just search heater core, also I have a chilton repair book and it had some useful in it. You may want to pick one up if you don't already have one. Good luck.
Old 03-24-2011, 07:54 PM
kevlar974's Avatar
kevlar974 is on a distinguished road
its not as bad as it seems a little time consuming only p.i.t.a. i ran into was removing the black box that surrounds the core. manual that i had said remove bolts holding it to firewall from inside the passenger compartment but i had 3 or 4 that were run through from the engine side and were down behind the engine.
Old 03-24-2011, 10:27 PM
idrd's Avatar
I have a 96 4dr 4WD. In regards to that cover for the heater core I guess I lucked out, there were all on the insdie and easy to get at.
Old 04-30-2011, 07:15 AM
Hey Guys
Thanks for all the great info. It certainly helped !
bamablazer57
04-05-2014 10:50 PM
zantam06
08-04-2012 02:00 AM
Matty man
11-22-2011 08:52 PM
trstno16
Engine & Internal
19
06-21-2011 08:12 PM
cc4usa
10-31-2009 09:22 PM
Quick Reply: 2000 S10 Blazer - Heater Core Headache
