2001 Chevy Blazer Problems
My check engine light is on steady. When accelerating or going up hill it flashes. I have changed plugs, wires, distr. cap, fuel filter, MAF sensor and this doesn't help. Any suggestionswould be appreciated.
Thanks.
Thanks.
RE: 2001 Chevy Blazer Problems
have you checked the codes? i would have done that before replacing the MAF sensor hoping for a fix.
autozone will check the codes for free if you dont have access to a code reader
this would recieve a LOT more attention if it were in the appropriate section. it would also be more helpful if you put your truck info in your signature.
*Moving to 2nd Gen Tech*
I agree with the above. You really shouldn't just take to replacing components without taking a look at what the PCM is telling you is wrong. Especially the $$$ MAF sensor...
I've always heard that if the Check Engine light starts blinking it's not safe to keep driving the vehicle. You could always just buy your on Code Scanner, they go for 50-60.00 especially now with the holiday sales. I purchased one and it has saved me alot of trips to Autozone.
It could be as simple as the fuel cap not being on right. And by not right, I don't simply mean you didn't tighten it. I've had it before where it didn't seat properly. The light came on and I was worried. Checked this forum and found the gas cap suggestion. I went and checked the cap (tried to crank it down tighter) and it was as tight as it would go. The light stayed on for 2 days. Before I could get a chance to check the trouble codes, I filled up with gas, and about 5 miles later the light went off (the error codes seem to take several miles to clear out). I'm positive the gas cap was tight when I checked a few days earlier (it was clicking when I turned it), but obviously that was it. It must have not been seated properly or something.
A flashing CEL is bad... That means that there are events occuring in the engine that could cause severe damage. If you ever get a flashing CEL, the vehicle should be parked. If that is not an option, then gingerly drive it until you can get the problem repaired. Typically a flashing CEL means that the PCM is detecting violent misfires that are out of it's control.
I thpought my owners manual said when the CEL is flashing it means the emissions system has been deactivated.
hlaverty06
03-05-2014 07:14 PM
ChevyMane808
04-05-2013 10:51 AM
upblazer95
04-04-2009 08:27 PM
beeneeb
12-07-2004 05:10 AM
