2001 blazer zr2 will stumble and die?!?!? need help!
2000 zr2 put a code scanner on it. Ok here is the info I got. Says no codes stored. Got it to run for 3 min then stumbled and shut off. Under dtc's it says INC next to cat monitor and n/a next to sec air system and INC next to EGR system and mil status says off is that normal? Everything else says ok next to it.
Truck will run for a few min then stumble and die and not restart for a few days. Has new fuel pump, wiring for pump, dist, ign module, cam sensor, coil, fuel filter, etc
Also it does not have a cat and never through a code for it..
My first thought was Fuel pump and Ill tell you why, I bought a fuel pump off line for like 80 bucks and this thing was new in the box. Two month's later I was buyin a new one and the guy at chevy said it had to be A/c delco or delfi ($226). But the problem I was having was the fuel pump would work until It got hot then the truck would shut off, but it would start again when it cooled off. Next time you drive it and if shuts off turn the key back and forward and see if you here the pump running.
