2001 Chev. Blazer No heat!!!
Old 12-29-2008, 01:42 PM
Jeff Brooks is an unknown quantity at this point
Default RE: 2001 Chev. Blazer No heat!!!
To be honest, I don't know. I thought it might have gone to the vacuum driven ***** for the climate controls, but the one line that goes into the firewall near the heater hoses might be all the vacuum the climate control needs. So it might go to some emission control near the fuel tank? not really sure.
Old 12-29-2008, 07:23 PM
rsheltro is an unknown quantity at this point
Where it disappears into the fender is just a vacuum reservior on a 1998 with CCC, don't know about other years. I just went through this mess with my 1998 on Christmas Morning.
Old 12-29-2008, 07:36 PM
Jeff,
I just reread your post. Your figure 3 and 4 don't jive. Your figure 3 is correct. If vac lines were hooked up as shown in fig 4, your front axle would not engage and your climate control would act funny during periods of low vacuum.
Just to shed some light on my recent findings:
1. The vac source should go to the BLACK side of the check valve.
2. The side directly opposite and inline with the BLACK side of the check valve goes to the vacuum reservior, which is located in the fender under the ABS stuff.
3. The small line exiting the check valve at a 90 degree angle is two fold- the larger rubber hose running towards the passenger side of the vehicle goes to the transfer case switch which controls your front axle engagement, and the hard plastic line (shown in the lower right hand portion of figure 4) goes to the climate control system.
walisha
11-03-2009 07:13 AM
MadMatt
11-17-2008 05:37 PM
mrsbw
01-05-2008 12:03 PM
FLIPSKATE07
12-17-2007 04:02 PM
kc2iyh
10-23-2007 02:14 AM
Quick Reply: 2001 Chev. Blazer No heat!!!
