2001 Chev. Blazer Won't Start
Old 10-21-2007, 11:59 AM
kc2iyh's Avatar
kc2iyh is an unknown quantity at this point
Default 2001 Chev. Blazer Won't Start
The battery shows around 10 volts. Kinda low. But I would think it would still be enough to start. Also, the dash lights all come on. When I turn the key to ignition, it will not even try and turn over. Everything but the check engine and battery light turns off. Any help to troubleshoot would be good.
Old 10-21-2007, 12:05 PM
Default RE: 2001 Chev. Blazer Won't Start
10volts with next to no load is very low. If you have a battery charger, try charging it back up.
How old is the battery? It's possible you have a dead cell. If you have alternate transportation, you can remove the battery and take it to an Advanced Auto or Autozone and have them test it. If you are able to get the truck started, you can take the whole truck to one of the aforementioned stores and they can check the alternator as well.
Old 10-22-2007, 06:21 PM
gocartone is an unknown quantity at this point
10v is WAY to low to start your blazer!
percentage of charge
12 volt battery voltage
specific gravity
100
12.70
1.265
95
12.64
1.257
90
12.58
1.249
85
12.52
1.241
80
12.46
1.233
75
12.40
1.225
70
12.36
1.218
65
12.32
1.211
60
12.28
1.204
55
12.24
1.197
50
12.20
1.190
40
12.12
1.176
30
12.04
1.162
20
11.98
1.148
1.134
Old 10-23-2007, 02:14 AM
thegr81's Avatar
yea that is way to low to start a vehicle charge it if it holds a charge good if not time for a new one
walisha
11-03-2009 07:13 AM
Stng5pnt8
12-29-2008 07:36 PM
MadMatt
11-17-2008 05:37 PM
mrsbw
01-05-2008 12:03 PM
FLIPSKATE07
12-17-2007 04:02 PM
Quick Reply: 2001 Chev. Blazer Won't Start
