2002 Blazer ls Heater core removal
  #21
Old 01-05-2008, 01:49 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: 2002 Blazer ls Heater core removal
It sounds like you have left off or damaged/pinched your vacuum harness to the hvac control head. Check and make sure you have solid connections...it could also be that you twisted the box when you pryed it off of the firewall and broke the defroster valve (the little door inside the case).
  #22
Old 01-05-2008, 05:09 PM
Chevy Lover's Avatar
It just so happens that I have the same problem right now. The air blows good through the vents but hardly at all from the defroster or the floor.
I found that this mode control unit seems to be weak 'cause if I assist it to full travel then I have full air flow.
This is on the drivers' side.
[IMG]local://upfiles/2910/67D1EE06003D4B27AF24C81C7DC89C8C.jpg[/IMG]
  #23
Old 01-06-2008, 12:21 AM
sean bamf's Avatar
sean bamf is an unknown quantity at this point
thanks chevy lover but there is one thing that i dont undertsan about that is that when i turn the **** to chang the mode it doesnt like click anymore its werid
  #24
Old 01-06-2008, 02:59 AM
Click? Where was it clicking before, at the switch?
  #25
Old 01-06-2008, 03:01 AM
sean bamf's Avatar
like when you turn the know to put the air at your feet it would click it to place when you turned it
  #26
Old 01-07-2008, 02:07 AM
Hmmm, check the switch....
  #27
Old 01-07-2008, 09:11 AM
sean bamf's Avatar
i already did like evrything else works but the mode **** i tryed everything i could think of
  #28
Old 01-07-2008, 10:50 AM
quinnman105's Avatar
quinnman105 is an unknown quantity at this point
Hmmmmmmmmmm thats weird
  #29
Old 01-09-2008, 07:18 PM
sean bamf's Avatar
yeah, and everything is put back together right
bamablazer57
04-05-2014 10:50 PM
error_401
12-10-2013 04:07 PM
Psychotacon
02-03-2013 10:32 PM
Static 90 C1500
01-21-2013 07:43 PM
aspenpup
07-03-2005 06:56 AM
Quick Reply: 2002 Blazer ls Heater core removal
