2003 Blazer 4dr No Defrost/Floor Heat
Old 08-26-2012, 07:29 PM
3D_Illustrator's Avatar
3D_Illustrator is an unknown quantity at this point
Default 2003 Blazer 4dr No Defrost/Floor Heat
Blower works, AC works, Heat works, No Defrost or Floor Heat.
How can I tell if the blend door actuator is faulty or if it is the control switch (AC/Heater/Defrost blower door selector switch. There is adequate vacuum to the control switch itself, but rotating the switch does nothing other than turning On/Off the AC or Heater. I disconnected a vacuum hose (Grery) from an actuator and have no vacuum in the hose regardless of where the switch is turned. Does that mean the switch is leaking vacuum and is bad?
Old 08-27-2012, 08:35 PM
I got a used switch assembly from a local yard and it fixed the problem.
reed2003
06-16-2011 07:15 PM
starcruiser
10-17-2009 10:52 AM
65longroof
14
05-02-2009 04:58 PM
ZQ8 Blazer
10-27-2008 09:04 PM
dunontme
09-22-2008 09:49 AM
Quick Reply: 2003 Blazer 4dr No Defrost/Floor Heat
