2004 Chevrolet S-10 Blazer No Radiator Drain Plug - Page 2 - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 12-23-2007, 06:32 AM
Default RE: 2004 Chevrolet S-10 Blazer No Radiator Drain Plug
Those drains are in the block and haven't changed since '85 for the most part.
The picture posted in the first post here shows the petcock as it has been since '96, but maybe they have it sealed off inside. Still looks like it has the 1/4 turn features in the extension... That is very odd that they would remove it...
Old 12-23-2007, 04:16 PM
Chevy Lover is a jewel in the roughChevy Lover is a jewel in the roughChevy Lover is a jewel in the rough
You're absolutely right Kyle, I should get more sleep.
I was looking at the manual for draining the rad and those were the pics thaey showed. I guess what they were suggesting is that you drain the block because there is no radiator petcock, as Koreyhas previously stated.
I think I'd go with Tims' suggestion to pull the lower rad hose.
Old 12-24-2007, 04:46 AM
BTJustice is an unknown quantity at this point
Quote:
ORIGINAL: Kordog
You will not find a pet-**** on these newer ones. GM for some reason has left them out of the factory radiators. I ahve run into quite a few GMs now that have the provision for it, but do not have it drilled out for a plug. HTH
I guess they want people to get frustrated with working on their GM vehicles so they start bring them to the dealership so GM can pay out all the pensions.
I still wonder what the smaller thing sticking out of the right side of the pet-**** pictured in the original post is.
Old 12-24-2007, 04:57 AM
Looking at the picture closely you will notice the groove for the metal pin used on the white plastic drain plug is not completely cut out either. I understand what has been said about the 1/4" fitting, but that is usually on the white plastic drain plug itself that would stick out of the pet-****. In this case, there is no plug apparently and nothing to turn with the 1/4" extension.
I also changed the coolant out in a 2003 S-10 which looked like the picture above except it had the white plastic drain plug sticking out of it (which I carefully removed and replaced with a black plastic aftermarket thumb-turn version). It didn't have the smaller thing sticking out of the right side of the pet-**** as pictured above either.
Old 12-24-2007, 08:28 AM
The smaller thing sticking out the side is the actual drain. The 1/4 turn white peice of plastic normally seals this off when it is turned in. Once turned out, it will uncover the port and drain. The 'nipple' is there so that you can slide over a piece of tubing and direct the coolant where you need to.
Seems GM liked to mess around with this... Odd. Penny pinching at its best. You know an engineer didn't make the decision to remove such a thing.
Old 01-05-2008, 12:44 PM
Kordog is an unknown quantity at this point
Kyle, I am not 100% sure when they started that pet-**** delete, but I have seen it on allot of new cars of all makes. It is very annoying, but from what I have heard from my radiatior suppliers is they are doing that because the leaking from the pet-***** have been too much ofa problem so they eliminated it all together. I don't know if that is true or not, but it does make sense, at least on chryslers, because those pet-***** SUCK!!! They almost always leak after removing them.
Closed Thread
Thread Thread Starter Forum Replies Last Post
The dreaded radiator drain plug.... Davecubs14 2nd Gen S-series (1995-2005) Tech 7 02-06-2015 03:03 PM
Flush radiator drain plug B761953 2nd Gen S-series (1995-2005) Tech 13 10-29-2013 02:42 PM
Radiator drain plug broken, need advice on repair. HamToast 2nd Gen S-series (1995-2005) Tech 10 12-26-2012 10:35 AM
Is 2004 Chevrolet S10 4-Door Blazer easy to work on? billharryeobd2 General Chat 3 07-06-2011 03:51 AM
40 a plug is a plug is a plug? boulonman 2nd Gen S-series (1995-2005) Tech 4 03-05-2007 05:10 AM
Tags
2004, 98, blazer, chevy, cocl, drain, flush, location, pet, petcock, photo, pictures, plug, radiator, s10, upfiles89307dd5103e2b244ade84100d2ad6c9f96fjpg
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
