4 wheel drive wont work
Old 03-28-2007, 02:55 AM
jhill133's Avatar
jhill133 is an unknown quantity at this point
Default 4 wheel drive wont work
i have a 98 jimmy and the buttons on the dash just blink when i go to engage in 4wd and i can hear a click either behind the glove box or kickpanel on passenger side. any hints to the problem here maybe switch or the actuator. thanks
hillbillyinOhio's Avatar
Default RE: 4 wheel drive wont work
check your tcase fuse. if its blown, its the switch itself.
Old 03-28-2007, 02:57 AM
jhill133's Avatar
i have a 98 jimmy and the buttons on the dash just blink when i go to engage in 4wd and i can hear a click down by the kick panel on the passenger side. any hints?
Old 03-29-2007, 02:52 AM
jhill133's Avatar
wheres the Tcase fuse located
Old 03-29-2007, 02:59 AM
it is in your fuse panel. on my 97 blazer its fuse number 19. spot is marked 4wd. left side of dash,, facing the door.
Old 03-29-2007, 08:21 PM
jhill133's Avatar
the fuse isn't blown what else could it be>
Old 03-29-2007, 08:29 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
You probably have a code stored in your TCCM....you need to groung pin 13 of your DLC and check for codes....if you are not sure what a DLC,TCCM,code or ground is...then do a search on this site it has been covered MANY times.
Old 03-29-2007, 09:02 PM
Zygoat is an unknown quantity at this point
it is probably the "incoder motor" or the transfer case shift motor (they are the same thing) you can get them from most auto parts stores.
mirrorimij
06-08-2019 03:34 PM
wintfam@olemac.net
01-22-2011 04:54 PM
lizzj70
06-23-2010 06:57 PM
diceman721
10-25-2009 06:53 PM
huskerman18
10-19-2006 01:02 PM
Quick Reply: 4 wheel drive wont work
