Rear Defrost
Old 02-17-2007, 01:29 PM
scoot's Avatar
scoot is an unknown quantity at this point
Default Rear Defrost
My rear defrost is not working. When I push the button the light does not come on any more and neither the rear window or the side mirrors heat up I checked the fuse and put a new one in and nothing it was a 30amp fuse if I was checking the right one any other ideas.
Thank You
Old 02-17-2007, 02:23 PM
hillbillyinOhio's Avatar
Default RE: Rear Defrost
get a DMM and check for power at the switch and at the leads in the back. might be a loose wire or someting.
Old 02-18-2007, 04:54 AM
Chevy Lover's Avatar
If you fix the defogger, that should also fix the heated mirror problem. It could be loose wiring, a relay or the HVAC control module.
Do you know the a/c RPO, is it C68?
Old 02-18-2007, 12:22 PM
Ac RPOs are from C60 - C69
88s10Blazer
09-11-2013 02:41 PM
ratrodsare4ever
04-12-2011 08:57 PM
94BlazerPA
05-17-2010 08:32 PM
tscott
10-26-2009 09:23 PM
kakn
12-12-2006 01:04 PM
Quick Reply: Rear Defrost
