4X4 i need help!!!
4X4 i need help!!!
Replaced vacumn switch encoder motor checked actuator and everything is fine the cord is not seized up i start car press 4hi or 4lo and the light flashes then goes back to 2hi when you press the button you can hear the tccm in the passenger side kick panel click. Can anyone help me???
I would keep trying several more times, just to build up enough faults in the TCCM that it might give you more codes if you run the diagnostic one more time. If nothing comes up in the diagnostic, then it might be a bad sensor at the front diff. (the one that tells the TCCM if the axle shafts are joined).
