4X4 i need help!!!
Old 02-24-2013, 04:33 PM
jhug1994's Avatar
jhug1994 is an unknown quantity at this point
I've replaced tccm, encoder motor, vacumn sensor on transfer case the sensor on the front differential still clicks and doesn't engage the 4x4 actuator does not have vacumn but I have vacumn at the transfer case any help please?
Old 02-24-2013, 08:56 PM
rockbuggy4x4's Avatar
rockbuggy4x4 is on a distinguished road
time for a np203 swap! lol just kidding. hav u tried it in park, neutral, 1st, 2nd, drive, reverse? also what is your engine rpm while going into 4 hi? if that doesnt fix it, try driving slow ( in gear foot off brake, no need for gas). good luck.
Old 02-24-2013, 09:07 PM
aa21830's Avatar
aa21830 is on a distinguished road
Originally Posted by jhug1994
Replaced vacumn switch encoder motor checked actuator and everything is fine the cord is not seized up
In your first post, you indicated that the 4x4 actuator was fine? Without vacuum at the actuator, it won't work. If you have vacuum at the transfer case but not at the 4x4 actuator, then you have either a leak in the vacuum line from the t-case to the actuator, or the vacuum lines were reconnected incorrectly at the switch on top of the t-case.
Old 02-25-2013, 06:57 AM
jhug1994's Avatar
I'm gonna have to find the vacumn line an it's at 600 Rpms the whole time it just flashes still
Old 02-25-2013, 08:40 PM
jhug1994's Avatar
I put a vacumn pump on the actuator sucked diaphragm down and tried to moved the front driveshaft it was locked in so i decided to just bypass the vacumn system completely and just install a pull cable.
evlblkwpnz
12-18-2009 08:26 AM
sdm1234
02-07-2008 06:16 AM
black95blazer
12-11-2007 05:45 PM
blazinloud
26
03-04-2007 03:25 PM
Quick Reply: 4X4 i need help!!!
