4x4 reset
Old 12-19-2009, 06:18 PM
spud-truck's Avatar
spud-truck is on a distinguished road
Default 4x4 reset
I have a 95 Blazer 4x4 (stock) and I have to keep reseting the computer to get the 4x4 hi to work. 4 lo still works fine by putting it in nuetral and hitting the switch then shifting into drive. I can then shift it from lo to hi in the same manner once in lo range. If Im in drive and try to use on demand it just blinks and goes back to 2wd. This is a three button switch.
Any ideas?
Dan
Old 11-12-2018, 01:10 PM
Carolyne Price's Avatar
Carolyne Price is on a distinguished road
Default 4x4 Reset Sequence 2001 Chevy Blazer Zr2
Any ideas?
Dan
If all else,...There is and I have succesfully used before, a 4x4 reset sequence to fix this kind of issue.
Old 12-23-2018, 05:18 PM
Default Lost 4x4 reset sequence
I used to have it written down but have misplaced it. I can't find anything on the internet either for this 4x4 reseting sequence. Wondering if you have ever used or heard of ?
Old 12-27-2018, 04:08 AM
error_401 is on a distinguished road
IMHO The 95 still uses the same shift motor/solenoid the 94 did. But the control is integrated into the ECU instead of being a separate control box.
The reason on the 94's to shift only between 2HI and 4LO is the encoder switch. On the 94 it allows for a couple of switchings before it has accumulated enough faults to go into a kind of "limp" transfer case mode. Then it will allow only the shifting from 2HI to 4LO. I guess that the 95 may be the same.
Just a thought.
I would start looking into the reason for the erratic shifting, rather than just to reset.
heavychevytruck'94
01-08-2015 08:50 PM
ryndraeger
03-12-2014 09:51 PM
greatwhite
07-17-2013 06:53 PM
Sway
01-12-2009 08:29 AM
EljayK004
12-21-2008 08:43 PM
Quick Reply: 4x4 reset
