p1345 after intake gasket R&R
Old 08-08-2011, 02:15 PM
josephdstone's Avatar
josephdstone is on a distinguished road
Default p1345 after intake gasket R&R
I had a coolant leak from the driver's side intake manifold gasket that I replaced today. I got everything back together and put the distributor in and the blazer started fine but threw a P1345 code. I cleared it a few times just to see if it would go a way and of course it did not.
I didn't have this code before I replaced the gasket and I saw that the dizzy being one tooth off could cause this to happen, but will the lack of one screw on the distributor cap also cause the P1345 code as well. I seem to have lost one of the screws to the cap and have to go buy another cap since I double I can find a replacement screw lying around.
By the way it's a 98 Blazer 2WD
Old 08-08-2011, 02:39 PM
xgiovannix12's Avatar
here ya go check this out it may help you
https://blazerforum.com/forum/diagno...plained-35138/
Old 08-08-2011, 02:41 PM
pettyfog's Avatar
Well, if the rotor being loose will cause it, I'd have to think a loose cap would too...
Automotive Advice - Auto Repair Questions and Answers: Engine Trouble Code P1345
Sure will be interesting to find out if the screw fixes it.
_
Old 08-08-2011, 04:36 PM
Yeah, that would certainly be interesting. I'll post back and let you guys know if that actually fixes it. I did read something about if the dist. is one tooth off then it will throw that code but I can only put it in how it is in or 180 deg. from that point. It doesn't seem to allow the dist to seat properly in any other configuration.
Old 08-08-2011, 05:17 PM
The oil pump drive is likely what is causing it to not want to drop in. Sometimes the drive can allow for one position that feels & looks right, but is 1 tooth off. After that, it won't let you go back without manually moving it with either a long screw driver, or an old distributor with the gear teeth ground off.
Old 08-08-2011, 05:24 PM
How far down would you say the oil pump drive is and how would I know if I had actually turned it? I did remove the Crank Position Sensor to clean it up just to make sure there wasn't any metal stuck to it but that didn't help at all.
Old 08-08-2011, 05:27 PM
kevlar974's Avatar
kevlar974 is on a distinguished road
https://blazerforum.com/forum/tech-a...-timing-24373/
This proceedure and a long screwdriver (like swartlkk described) should get it on the right tooth.
Old 08-08-2011, 05:47 PM
The oil pump drive fits into the bottom of the distributor so it is about as far down as the distributor is long from the mounting flange to the bottom of it. You have to look down through with a flash light to see if you've moved it. It can definitely be a test of patience if you are using a screw driver. The old distributor is by far and away easier!
Old 08-09-2011, 11:48 AM
I have the timing all messed up now after trying to move the oil pump shaft a bit. I'm going to have to start at square 1 with this thing... 1 person timing jobs suck!
Old 08-09-2011, 12:52 PM
Okay, wasn't so bad, just followed that link you gave me Kevlar and followed the instructions. Ended up getting a hacksaw blade to turn the oil pump shaft. I realized that I was jabbing aimlessly at the job rather than thinking it through and making sense of it all. I appreciate you guys taking the time to explain things. By the way, that solved the p1345 light issue!
Quick Reply: p1345 after intake gasket R&R
