95 4.3l vortec will not start!!!!
Old 05-22-2012, 09:19 PM
blzR's Avatar
blzR is an unknown quantity at this point
How's this non-staring blazer issue unfolding Lanny? Is there a Delco fuel pump in there yet?
  #22
Old 08-21-2012, 10:45 AM
Lanny's Avatar
Lanny is on a distinguished road
Ok sorry for the extreme delay y'all...got side tracked. Lemme get y'all caught up to speed.
New Parts..
Fuel pump ( delco )
Fuel screen
Fuel filter
Spider assembly
Plugs
Wires
Cap
Rotor
Ignition coil
Fuel relays ( both pump and control)
Egr valve
Tps
Air charge sensor
Iac valve
Now it is running and driving with one hitch....I am right back to the original pre failure sympotms....
Waving idle
Pop on idle
Weak idle
Runs very rich
Failed emissions for low idle hpm ( standard reading is 120 on flat idle....my reading was 954 on flat idle) a friend of mine works at the ancora facility and got.me threw the second time but obviously didn't make the problem go away. It just gave me two more years to fix it.
Thinking maybe the stater on the distributer ...should i just got ahead and replace the whole distributor? I can get a reman from advance for 100.....any ideas?
  #23
Old 08-21-2012, 07:50 PM
Presti7's Avatar
Presti7 is an unknown quantity at this point
Did you have a vacuum leak to the heater/ac controls on that vacuum hose going into the cab?
  #24
Old 08-27-2012, 02:01 PM
Lanny's Avatar
Where exactly is that hose?
  #25
Old 08-29-2012, 06:42 PM
LannyL81's Avatar
LannyL81 is on a distinguished road
Follow the vacuum hose from the ball under the hood, driver's side. Follow it and check for leaks or just plug the hose coming off the engine for now until you get it running.
  #26
Old 08-29-2012, 09:58 PM
Dadatone's Avatar
Dadatone is on a distinguished road
LannyL81, what do you mean by "the ball under the hood, driver's side"?
  #27
Old 08-30-2012, 10:56 AM
LannyL81's Avatar
On Lanny's 95 model there is a vacuum reservoir (ball) under the hood on the driver's side. In later years...not sure just what year, the reservior was moved to inside the driver's side front fender.
Does this make sense?
  #28
Old 08-30-2012, 01:31 PM
Dadatone's Avatar
Yes. I was hoping you would say this. My vacuum canister is located in the drivers side fender and I think mine is either bad or the hose is bad. This is why I asked the question. Sorry, didn't mean to interrupt.
  #29
Old 09-12-2012, 11:55 AM
butterdude63's Avatar
butterdude63 is on a distinguished road
Did you figure out your problem yet?
  #30
Old 09-14-2012, 08:33 PM
Lanny's Avatar
Not yet....sry for.the tardy responces...I'm at the mercy of my phone and sprints reliable network at.the moment ...went looking for vacuum leaks again found nothing....going.to refocus on ignition, just gonna throw a new distributor at her see what happens.
mrblonde108
07-17-2017 07:52 PM
fjallasport-ram
02-23-2011 08:30 AM
extreme
12-01-2010 06:08 PM
debo42
09-14-2009 06:34 AM
96blkblazer
02-26-2009 04:29 PM
Quick Reply: 95 4.3l vortec will not start!!!!
