2001 Blazer 4wd service light blinking
Old 06-05-2009, 02:01 PM
bir11's Avatar
bir11 is on a distinguished road
Default 2001 Blazer 4wd service light blinking
Service engine soon light is blinking and when go to accelerate its feels like it don't want to go and is slugish not really alot of power. Could it possibly be the spark plugs? the wires looked ok.
Old 06-05-2009, 02:43 PM
oisinirish's Avatar
You need to get the codes read. Most of the chain part stores do it for free.
Old 06-05-2009, 03:18 PM
If the light is on, it means the TCCM has stored codes. Definitely get them read. Problem will likely be that the code scanners used at Autozone/Advance Auto/etc will not be able to access the TCCM for codes. It will need to be a higher feature scan tool for this type of access.
Old 06-05-2009, 04:58 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
Just to be clear here is it the 4WD or Service Engine Soon light blinking? Your post title said 4WD. "If a misfire condition exists that could potentially damage the catalytic converter, the diagnostic executive will command the MIL to flash at a rate of once per second during the times that a catalyst damaging misfire is present". (from the GM Service manual)
A good scanner/reader can see the misfire history in the computer so you can narrow it down to specific cylinders, but if you don't know the history of the truck (last time it had a full tune up) plugs, wires, cap & rotor is an excellent place to start. Appearances of the wires doesn't mean much. A better back yard test would be to start the truck in the dark and spray the wires with a spray bottle of water and watch for a sparky light show.
Old 06-05-2009, 08:14 PM
Ha. Yeah... I read the description and missed the first two words of the post.
Plenty of posts on the flashing CEL.
Old 06-06-2009, 04:05 AM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
Why wait until dark? Just grab one wire at a time. You'll know if they are leaking. Only bites for a second.
Bolbol
13
08-12-2015 01:47 AM
aconnerb
06-17-2015 03:02 PM
fixer34
07-28-2013 10:42 AM
ttwo
10-28-2010 12:35 PM
Mike2Cubed
03-08-2008 08:27 PM
Quick Reply: 2001 Blazer 4wd service light blinking
