95 Blazer Rough Idle - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 01-17-2012, 07:04 AM
Paulpolar600 is on a distinguished road
Default 95 Blazer Rough Idle
I've got a 95 Blazer (the one with the vortec plaque on top) That I've just replaced the fuel pump, filter, and spider injector with new (not reman). And now it refuses to idle once warm. When cold the truck runs flawlessly and even when warm but it idles soooo rough when warm it sounds like it's going to die! Anyone had a problem like this? Could this be a plenum gasket leak?
Old 01-17-2012, 09:15 AM
88skisupreme is an unknown quantity at this point
I had this problem too, try cleaning the IAC valve
Closed Thread
Thread Thread Starter Forum Replies Last Post
rough cold start idle and rough running blazerguy22 2nd Gen S-series (1995-2005) Tech 10 11-15-2013 12:50 AM
1997 blazer 4.3 with rough idle and stumble off idle blazer chris 2nd Gen S-series (1995-2005) Tech 1 12-08-2011 10:56 AM
Rough Running, Rough Idle, Idles Hot nhguy261 Engine & Transmission 17 12-30-2010 02:41 PM
Bogging down when at idle/ Rough Idle solution 97BLAZE4X4 2nd Gen S-series (1995-2005) Tech 1 02-07-2010 08:33 PM
idle rough runs rough c10jm Engine & Transmission 7 08-12-2008 06:34 PM
Tags
1995, 95, adjust, blazer, blazerrough, blazzer, blogging, chevy, cold, idle, idles, rough, ruff, stumble, uneven
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
