96 blazer dies, restarts while driving
Blazer will run fine , sputter a bit shut down and fire right back up while driving. Cel was on since i purchased, but after tryimg to fix the issue it has came off. Pulled codes for bad vac and tps. Fixed both and while i wad in there went for the new spider injectors. Had some solid life! For a couple days. It definately runs smoother but thinking the next step may be the fuel pump itself? Possibly explains the random cutout? If it is the pump, a new one online runs 60 while oreillys gets 300plus for one. From what ive been hearing even the good ones are crap? Whats the best way to find if it is the fuel pump?
The pressures were low, 45 when supposed to be in the 60s. Went ahead and put the new pump in. Still having the same issue. Bought a filter, hoping that might be an issue too but makes sense to leave the old one in for now, maybe catch some of the crap from dropping the tank. Hopefully that resolves it? Not sure where to go next if it doesnt
https://blazerforum.com/forum/articl...-switch-33465/
tammyjcks
03-29-2020 10:05 PM
Ratt
11-13-2013 07:34 AM
Joecrack85
07-22-2012 12:17 AM
sindy1232
08-22-2008 09:38 AM
nickaf7172
10-06-2005 03:36 AM
