97 Blazer very hard to start
Old 12-04-2012, 10:45 AM
stickman's Avatar
stickman is on a distinguished road
Default 97 Blazer very hard to start
First post ever here. I tried to do some homework before posting, but having a terrible time getting my Blazer to start. It takes several attempts, then th RPM's are very low, then gets up to normal speed, if I'm lucky enough to get it started.
Here is what has been done recently
New fuel pump (AC Delco)
New injectors (changed the spider assy to the MFI, Thanks for the info!)
New plugs, wires, cap and rotor
The pump was very noisy, and the old injectors/regulator were leaking, hence the change.
Rechecked the fuel pressure, holds at 59 lbs for 10 minutes.
I'm currently at a loss, but thinking maybe the ignition switch?? Any suggestions?
Old 12-04-2012, 12:06 PM
spittybays
Guest
Posts: n/a
That all sounds good but theres some stuff to do before you start looking at the ignition switch.
Give your MAF, if you have one, a good cleaning with Maf cleaner.
Clean TPS, IAC and entire throttle body with carb-cleaner. EGR, if you have one also.
If you have a scan tool look at air intake temp and coolant temp. They should be within three degrees at cold start. If you don't you can still test it with a multi-meter on ohm scale. This chart should work for both temp sensors.
http://i11.photobucket.com/albums/a1...nsor_Chart.gif
Old 12-05-2012, 10:33 AM
stickman's Avatar
Default Will do...
I'll get to the EGR, MAF TPS and IAC as son as I get a little break form work. I also found my battery wasn't so good this morning. Itwas low on cranking amps. Replaced the battery, and she fired up up right away.
I'm still going to clean out the parts you recommended. Thanks for helping.
Old 12-09-2012, 11:20 AM
stickman's Avatar
Default She's looking good.
I cleaned the throttle body, IAC MAF and replaced the TPS. I could not see any voltage swing on the TPS when checking. I did have the reference voltage. Anyway, after replacing and driving for a bit, all seems well. This morning, my baby cranked up first time. Thanks for the help!
er0ck273
70
12-04-2014 07:08 AM
chrisnlbc
17
04-01-2012 08:10 PM
danb2760
12-24-2010 04:08 PM
coyote0630
02-09-2009 12:16 AM
Kellen
09-22-2006 04:41 PM
Quick Reply: 97 Blazer very hard to start
