98 Air Conditioning Electrical Problem
Old 06-03-2010, 10:00 PM
akustom57's Avatar
akustom57 is on a distinguished road
Default 98 Air Conditioning Electrical Problem
OK, I'm new on here but have searched and can't find an answer for my problem, its a 98 with climate control. Here's my problem; air is not working in auto or manual settings, took to shop and pressure was fine, when you hit the air button on dash it blinks 3 times but clutch doesnt engage, check fuse & relay & both ok, I am not getting any voltage to the high/low pressure sensor and when I jump across it nothing, I can jump across the relay at pins 3 & 5 and the compressor kicks on, have switched relays with same results. I can take and run a jumper from a good ground to the ground side of the relay coil and the compressor kicks on but still nothing at the hi/low pressure sensor. not sure if it is an ambieant sensor or even how to check them. Any help would be appreciated, Thanks
Old 06-04-2010, 07:18 AM
The low pressure switch just grounds out the circuit so one side should have ground and the other goes to the PCM.
The high pressure switch connects the A/C REQ output from the HVAC control module to the PCM.
The PCM tells the A/C compressor clutch relay to energize by completing the ground circuit.
Here are a few wiring schematics for you:
Attached Thumbnails 98 Air Conditioning Electrical Problem-98_auto_ac_comp_sch.gif   98 Air Conditioning Electrical Problem-98_auto_ac_gen_sch.gif
Casole6
06-30-2012 07:42 PM
dannydblazer
05-23-2011 09:48 AM
littleblueblazer
05-24-2009 04:14 PM
DrThorsen
04-14-2008 10:46 AM
myboo11009
08-22-2006 04:21 PM
Quick Reply: 98 Air Conditioning Electrical Problem
