dash lights
Old 07-31-2007, 12:33 PM
jordan0316's Avatar
jordan0316 is an unknown quantity at this point
Default dash lights
When ever I press the break pedal my dash lights dim to where they are barley readable. Any ideas what is causing this?
Old 07-31-2007, 12:41 PM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
Default RE: dash lights
What are you driving? (year, style, motor....)
Go to your local Advance Auto and have them check your Alternator. Before my alternator went up, I was noticing that the headlights would randomly dim and then come back. Also, the dash lights would dim....... If this is it, you're in luck because alternators are easy to replace. Not too cheap though.
Old 07-31-2007, 08:23 PM
jordan0316's Avatar
I have a 2004, 2dr, 2wd. I hope it's not the Alternator, if it is this will be the 2nd time I will be replacing it.
On another note, when I depress the break pedal, and the dash lights dim, if I activate the right turn signal they go back to bright. There is no change when the left turn signal is activated.
Old 08-01-2007, 11:46 AM
jordan0316's Avatar
uhhhhhh never mind... it went away...
Old 08-01-2007, 12:04 PM
well, the problem is still there... We don't have self healing wiring harnesses... But it could just be a bad connection on a plug or something...
mrspeedy69
05-23-2012 09:11 AM
new to chev
04-30-2012 09:03 PM
Steeltoe623
11-12-2011 03:10 PM
greendouglash
02-03-2011 05:13 AM
Aneurysm
13
05-03-2008 12:27 AM
Quick Reply: dash lights
