98 blazer, oil and water mixed... - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 10-03-2011, 04:25 PM
98'blazin713 is on a distinguished road
Default 98 blazer, oil and water mixed...
Ok guys, this is my first time at a project of this caliber. So any help, cmments, or advice would go a long way and would be greatly appreciated. I have a 1998 chevy s-10 blazer in which the engine died on the road. It overheated. Got the truck home and checked fluids. Radiator was bone dry, and when I checked the oil, that's where all the coolant was!! So I am in the process of trying to pull the engine. Is it worth rebuilding or just get another?
Old 10-03-2011, 04:48 PM
grizzstang is on a distinguished road
IMO that would depend on how many miles it had before the meltdown and how far it was driven while it was overheating. Large amounts of coolant in the oil generally means a boat load of damage.
To me if you are taking it out anyway I would pull the heads off and look at the cylinders and pull the oil pan off to inspect the bottom end. You may get lucky.
Old 10-03-2011, 05:42 PM
Ok so there's possibly a way to repair without removing or am i going the right route? Im stuck at the moment trying to remove power steering pump. And where doing i drain power steering fluid?
Old 10-03-2011, 05:45 PM
xgiovannix12's Avatar
xgiovannix12 will become famous soon enough
id check over the engine if its worth rebuilding id do it you do have a blown intake gasket
Closed Thread
Thread Thread Starter Forum Replies Last Post
Spectre Performance CAI, a Story of mixed feelings 97CountryJukeboxLt Performance & Brainstorming 14 12-21-2011 09:16 AM
Tire rotation question-mixed size problem edphot2009 Tires and Wheels 1 04-21-2011 02:01 PM
96 blazer with water in oil and radiator chevycrazy2011 2nd Gen S-series (1995-2005) Tech 2 01-16-2011 08:06 PM
water in intake manifold and oil mrij 2nd Gen S-series (1995-2005) Tech 4 12-17-2010 10:39 PM
Tags
1998, 96, 98, blazer, chevrolet, chevy, coolant, engine, head, intake, mixed, mixing, motor, oil, pan, removing, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
