Lowering Kit
Old 01-11-2008, 12:51 AM
BlazinJay84's Avatar
BlazinJay84 is an unknown quantity at this point
Default Lowering Kit
I'm looking into lowering my blazer. Does this kit include everything I'll need.http://www.andysautosport.com/chevro...r00037788.html. Any advice ? Anyone have any pics of a 3 inch drop ?
Old 01-11-2008, 08:49 AM
LORCLAS's Avatar
LORCLAS is an unknown quantity at this point
Default RE: Lowering Kit
I think that kit is for an S-10. Blazer's have sealed front hubs so the spindles shown will not work. 2" drop spindles for a Blazer run about $200-$300.
Old 01-11-2008, 04:56 PM
thegr81's Avatar
Ok you can use that kit the only things you will need to purchase to go with that kit and I will list for you:
all these parts are from a 99 s-10 pickup this is what i converted mine over to for those spindles:
rotors with bearings
calipers
pads
brake line (make sure you get the one with the bigger oppening to fit from your hardline to you caliper ) the soft line is what your replacing
that is all you will need to swap over your front to use that kit!! suggestion hit up a junkyard for the list I gave you I did and I saved a ton of money!!
MattWarden
11-10-2007 07:02 PM
Blackout
Suspension Tech
10-27-2007 12:25 AM
vagnozzi
05-05-2007 10:32 AM
bhrconcepts
Suspension Tech
01-25-2007 02:04 AM
choi_kid
Suspension Tech
04-26-2005 02:17 AM
Quick Reply: Lowering Kit
