abs light on/control valve code c 1252 ??????
Old 06-24-2007, 03:02 PM
88blackzcand95blazer's Avatar
88blackzcand95blazer is an unknown quantity at this point
Default abs light on/control valve code c 1252 ??????
whats happen, i was wondering if anybody here could help me with my brake prob. vehicle is a 95 balzer 4x4 with 4WAL brake system
a few weeks ago i had my abs light come on and stay on after hitting the brakes pretty hard to get off the highway and geton to arest area ramp.
light came on after resarting the blazer (normal), then went out for one second, and then came back on and has not went out since
pulled the battery cable-light came backon immediately
pulled the abs fuse-light came back on immedaiately
finally took it to a "brake" shop and they pulled a code about the control valves not operating properly (code c 1252)
they told me it would cost arround 1200 parts and labor
just wondering if anybody has anymore info on this specific problem or the possibility/hassle of getting a junkyard control unit and swapping them myself ?
i am pretty mechanically skilled but have never messed with abs before any help would be very much appreciated
Old 07-12-2007, 05:25 PM
Default RE: abs light on/contol valve code c 1252 ??????
come on fellas, who wants to win the brake/abs guru of the year award?
any help or info would help me a ton thanks in advance
Old 07-12-2007, 05:46 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
I'd help if I knew anything about it but, sorry I have no idea about ABS stuff. All I know is mine comes on under heavy general braking for no reason sometimes, and sounds like its spazzing out when it does need to work in the snow and what not. I just don't trust it.
-Lenny
Old 07-12-2007, 05:53 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Bill, Kyle, Anybody? I only have limited knowlege about ABS systems else i would help.
Old 07-12-2007, 06:13 PM
C1252 ABS Inlet Valve Coil LR Circuit Short To Battery
However, your truck isn't truly OBD2 so I don't know how true this code is... Especially since this is one of the early generation ABS control units. I wish I could be more specific...
One thing that seems to be reoccurring in my references is the possibility of corroded connections. Maybe try pulling the connector off of the ABS pump and cleaning it.
Besides that, more often than not the only option is to replace the pump if you want to retain your ABS functions.
Old 07-29-2007, 10:00 AM
thanks so much guys i appreciate the help, sorry it took me so long to thank you, been real busy at work here
i'll try the connection clean up trick hope it works i am hearing more than a grand for a new abs pump installed!!!!!!
congratulations swartlkk you are the brake/abs guru of the year award
Old 09-12-2007, 05:53 PM
sorry about the delay i have been swamped at work (been driving the bike and crx instead)
whats the best solution to clean the electrical conections you described?
also i have found a couple junk yard blazers with what appear to be the same abs control unit. are they hard to swap and are they all interchangable or do i need a certain year/ model
Old 05-15-2008, 06:54 PM
i still have not fixed this problem, however after searching this site some more i came across module master and have contacted them to see if they can be of service to me. i'll update how things go. i hope they can fix it for arround $150 instead of the dealers $1,000!
Old 05-27-2008, 03:38 AM
Slnt Dnky is an unknown quantity at this point
That's where I sent my ABS module and since then I haven't had any problems with it. What I don't get, is how can a company like Modulemaster can fix the problem with USD150 in less than 2 days (it took longer to send & receivethe dam thing from Greece), and the local dealership has to quote you a new part.
gtmccormick
02-16-2013 08:06 PM
optimus485
05-12-2012 07:07 PM
damageinc98
07-12-2010 10:47 PM
waviaerith
05-22-2010 10:02 PM
stormshadow1
04-23-2009 09:46 AM
Quick Reply: abs light on/control valve code c 1252 ??????
