Rear Brake Drum Backing Plates for 1996 -- Out of Production
Old 10-01-2017, 07:24 PM
mdmccurr's Avatar
mdmccurr is an unknown quantity at this point
Default Rear Brake Drum Backing Plates for 1996 -- Out of Production
Hello Everyone,
My 1996 Blazer has almost 300k and the rear drum backing plates are completely worn out. I developed grooves in the contact points at about 200k and so I used a grinder to make the contact points smooth and flat. Now at 280k the grooves are back and they cause the rear brakes to grab and not release in a smooth way.
The original GM part numbers that I need are P/N 18012022 and 18012021. My dealer says that the parts are no longer available and he could not find them on nationwide search. Has anyone figured out a solution or found an aftermarket? Dorman makes the 1980's version but not the right version for 1996 with 4 bolt holes.
If I can't find the replacement part then I am going to take the old set to a machine shop and have the weld new contact points and grind everything smooth. Any other ideas?
Thanks,
Mike
Old 10-08-2017, 11:11 AM
1pickup's Avatar
1pickup is on a distinguished road
yes, they are for a Grumman LLV. Postal delivery vehicle based on an S10 chassis
djweisman
01-26-2016 05:38 PM
mdmccurr
04-17-2014 09:20 PM
Denominator
07-09-2011 09:07 PM
meredraven2
06-03-2011 05:01 PM
jetrider
01-24-2008 01:16 PM
Quick Reply: Rear Brake Drum Backing Plates for 1996 -- Out of Production
