Anti-freeze leak 95 S10 Blazer
Old 03-17-2013, 10:00 AM
IowaBrad's Avatar
IowaBrad is on a distinguished road
Default Anti-freeze leak 95 S10 Blazer
This is a 4.3 Vortec, 4WD, LT w/118,000 miles.
I have replaced the water pump and passenger side, front freeze plug and was convinced the problem would be solved. I replaced the coolent, idled the engine for approx 30 mins with no problem. I drove approx two miles and it overheated. There is no evidence of leaking in repaired areas and I can now see coolent coming from what appears to be a round hole in possibly the transmission. This is directly behind the oil pan. Any help would be appreciated.
Old 03-17-2013, 11:33 AM
puzzled's Avatar
puzzled is an unknown quantity at this point
does this have freeze plugs inbetween tranny and motor
Old 03-17-2013, 11:35 AM
puzzled's Avatar
may be heater core hose
Old 03-17-2013, 11:37 AM
Piski1982's Avatar
Piski1982 is on a distinguished road
There are two feeze plugs in the back of the block. Would be behind flex plate.
Old 03-17-2013, 11:38 AM
Piski1982's Avatar
Also check your intake manifold gasket
Old 03-17-2013, 11:43 AM
IowaBrad's Avatar
Does the hole I described make any sense? I doubt it's the tranny per se but it's in that area. I can cover this hole with finger and when finger removed, coolent definately coming from hole. The hole is approx 1/4" diameter. If it's leaking from the rear frost plugs, would this hole be the exit route?
I appreciate your thoughts.
Old 03-17-2013, 12:07 PM
puzzled's Avatar
yes this is the route it would take remove the tranny dust cove fill with fluid usa a flash lite to look between tranny and motor
Old 03-17-2013, 02:37 PM
IowaBrad's Avatar
Thanks, I'll get that dust cover pulled and see what it looks like.
Old 03-23-2013, 03:43 PM
IowaBrad's Avatar
I removed the dust cover and exposed the flexplate and torque converter. The coolant is definately coming from this area but there is no way that I can tell, to see the frost plugs. I hate to ask but what else would need removed to view them and what is required to replace them if that turns out to be the problem? Does the tranny need removed? Motor?
Thanks.
Old 03-23-2013, 03:59 PM
chestypuller's Avatar
Banned
chestypuller can only hope to improve
maybe the block cracked between the flexplate and motor
Quick Reply: Anti-freeze leak 95 S10 Blazer
