01 extreme ac issue
Old 06-22-2012, 12:17 AM
afish's Avatar
afish is on a distinguished road
Default 01 extreme ac issue
hello ust got a 01 blazer extreme was tol had a newer ac comp on it well the ac dont work checked the freon level wouldgo from almost empty to way overcharged when the comp would turn on what does that mean
Old 06-22-2012, 12:50 AM
50lb_cat's Avatar
Were you recharging it and the compressor began to short cycle? If so, then keep adding freon until the compressor stays on fully. Then the pressure will be steady.
Old 06-22-2012, 01:18 AM
afish's Avatar
yes i was. but stoped when i saw the gauge go way to the red now if i just put te gauge on it says its in the full zone but there is no cool air. the comp turns off and on when trying to add
hotrodclutch
Lowering Tech
04-24-2011 05:05 AM
Benedict1337
01-02-2010 08:29 AM
Newfiezedder
05-16-2006 08:28 AM
dubluj
12-12-2005 02:09 PM
FattyExtreme
08-14-2004 06:02 PM
Quick Reply: 01 extreme ac issue
