Auto shifter cable replacement - Blazer Forum - Chevy Blazer Forums
Reply
Thread Tools Search this Thread
Old 05-28-2010, 07:15 AM
robrote is on a distinguished road
Default Auto shifter cable replacement
The shifter cable has gone out on my 99 blazer, automatic (column shift). How difficult is it to replace the cable? Looks cut and dry under the truck, but the cable looks to go into the floor board. Anybody have any experience with this?
Thanks
Old 05-28-2010, 11:15 AM
It isn't too difficult. You will have to pull the lower hush panels off the dash to get at the steering column end, but it isn't too bad.
Old 05-31-2010, 07:39 AM
You're right Kyle, this was not too difficult at all. For those of you tackling the job, here were my procedures. Sorry, no pics.
-Under the car, snap of the end of the detent cable from the shift lever. A screw driver works nicely.
-There is a U shaped clip that holds the adjuster onto the bracket, connected to the trans pan. Pull that out and cable should be free at this point.
-Up top, remove the sill plate (held by 5 clips) and the kick panel (one clip). Pull the carpet back toward the seat as much as possible.
-remove the lower knee bolster panels (6 or so screws) and move them out of the way. No need to disconnect the E-brake cable. Remove the steel shroud around the column (4 9mm nuts).
-pry the plastic clip off of the accelerator bracket that the shift cable attaches to. There is another U shaped clip similar to the one under that car that holds the cable in its bracket on the column. Remove the clip, pop off the end of the cable with a screw driver.
-run your hand under the carpet and pad to give you some room to allow the cable to move freely along the floor pan. Pull the cable out from under the car.
-install the cable from inside the car through the floor pan. There is a large grommet that holds the cable in the floor. Reverse the procedure to install the cable.
Adjusting the cable.
-Once the cable is installed, but before you connect it to the transmission, put the gear selector in 'P'. On the cable at the trans pan bracket, there is a white plastic clip. Pull the clip down. This allows the cable to be moved forward and back. While the clip is in the down position, attached the end to the detent (make sure it is all the way forward in park. Once the detent is attached, snap the white clip back into place, and you're done. I did use some nylon ties to make sure the cable did not hang down or hit any moving parts. The whole job should take less then an hour. Cost, $100 dealer only item.
Old 06-22-2012, 04:55 AM
Bruce-li is on a distinguished road
Could you describe your experience in detail?
Reply
Thread Thread Starter Forum Replies Last Post
Center Column Shifter to Center Console Shifter matthewp Paint, Body, & Interior 2 05-25-2013 10:09 PM
Column Shifter to Floor Shifter Swap jasedude 2nd Gen S-series (1995-2005) Tech 0 11-24-2010 04:03 PM
Floor shifter to column shifter mod rbcar1 Steering, Suspension & Drivetrain 4 12-13-2009 10:20 AM
Blazer 95 4x4 manual shifter cable broken besthia 2nd Gen S-series (1995-2005) Tech 7 09-02-2009 06:12 PM
Tags
1995, 1999, blazer, cable, chevrolet, chevy, cost, pickup, removal, replace, replacement, replacing, shift, shifter, snap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
