axle shaft question
Old 09-25-2013, 10:45 PM
xillzxnickx's Avatar
xillzxnickx is an unknown quantity at this point
Default axle shaft question
I have a factory 10 bolt rear axle 8.5 ring and pinon not normal 7.5 or what ever it is
I need to buy custom axle shafts and am trying to avoid taking them out to measure them so I don't have to spend the money for gear oil twice
my first question is does the 8.5 use the same axle shaft as a 7.5 because isn't one a 30 spline (8.5) and a 28 spline 7.5
im also re gearing the rear will any 8.5 master rebuild kit would work right all the same internals as like a Silverado 1500 10 bolt for example
Old 09-25-2013, 11:18 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
i wanna say for us.8.5 is 30 spline,and about 28"
zr2 is 30 3/4"
Not sure on last question
Old 09-26-2013, 11:04 AM
Diaita's Avatar
Diaita will become famous soon enough
The only thing the axle shafts have in common is the bolt pattern.
With an uncommon axle like you have, personally, I would pull both axle shafts and measure them to be sure of bearing diameters and lengths. There isn't a lot of info online about them, and maybe they aren't all the same... I hate wasting money on custom parts.
I think any 8.5 LD overhaul kit will work.
Old 10-06-2013, 12:58 AM
Thank you yea I'm pulling them today and going to buy new rnp and install kit
xillzxnickx
Suspension Tech
09-25-2013 10:45 PM
jmaynard
07-12-2011 01:03 PM
Jiminy Crickets
03-31-2011 10:35 PM
Tony H
09-07-2010 07:45 AM
jsoluna
01-26-2010 08:20 PM
Quick Reply: axle shaft question
